Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] How to extract a lagrangian point using its ID and attach a glyph
Like Tree1Likes
  • 1 Post By Lollum
Old   January 4, 2017, 11:00
Question How to extract a lagrangian point using its ID and attach a glyph
Benjamin
elys is on a distinguished road
I have a particle simulation where I would like to visualize a single moving point out of a phase containing millions of points. I like to attach a glyph like a sphere to that point in order to see where this point is propagating. I've tried using a threshold (where I only can pick the scalars of the particles or phase ID) and some other filters without any success.
If I use a selection, I can pick any point and extract its data like particle ID, coordinates and so on, however, I have no idea how to use this information to visualize a glyph or smomething similar in order to track that particle. Does anybody of you have an idea how to achieve this?
Thanks in advance,
Ben
P.S. I'm using PV5.2 and .pvtu
elys is offline   Reply With Quote
Old   January 26, 2022, 12:57
Lorenzo Pedrolli
Lollum is on a distinguished road
Hi!
I have a similar problem. I traced down the issue to the fact that OpenFoam 9 tracks the particles by their original ID (origId). Upon importing the .vtk file, ParaView attaches to the Point ID according to a positional criteria, which is unrelated to origId.
It should be possible to either reorder the particles in ParaView using a filter, or during the VTK conversion, but I haven't yet gotten around to it.
However, in a newer version of PV (5.6) the filter "Temporal Particles to Pathline" can display the pathlines of the particles, allowing the selection of origId as tracking variable.
The selection tool "edit > find data" can be used too select a particle by origId. Once you selected the data you can use the filter ExtractSelection to track the single particle.
I hope this is useful for someone.
Cheers
Shah Akib Sarwar likes this.
Lollum is offline   Reply With Quote
glyph, particle, trace
