Home > Forums > OpenFOAM Paraview & paraFoam
Convergence validation with Plot Over Time
Old   February 9, 2017, 09:42
Default Convergence validation with Plot Over Time
Joseph Murray
jam68 is on a distinguished road
I have what I think is a simple question but I have been trying to solve it for days.
I have a large OpenFoam simulation of a system in a building. It is a buoyant flow and I am using 2.4 and paraview 4.1.0 on Linux/Ubuntu.
I load my results into paraview and all works fine. However, the group I am presenting to does not understand engineering units. They want all temperatures in C rather than K. I am creating a 2 view video of the simulation progression. The first thing I do is add a calculator that creates T_C by taking T - 273.15. I plot points in the main view (and will put cut planes to highlight the key areas). Everything works great.
I then create a split view and add a spreadsheet to inspect data items. Both T and T_C show up - all looks fine. I think select a few points as rows in the spreadsheet and hit plot over time. This is where the wheels fall off the wagon. I get an error that says T_C only exists for 1 value, 12 needed. At this point I have 12 time steps.
When I configure the plot over time I only have access to the original T not T_C (which I anticipated from the error). I thought I may have to put a calculator on the plot over time but can not find a way to do this.
Any suggestions on how to get the calculated T_C to work with plot over time OR how to apply a new calculator to the resultant plot over time?
I have attached a screen shot that shows what I am doing.
Any help is greatly appreciated.
Best regards - Joe.
File Type: jpg Screenshot from 2017-02-09 08-12-14.jpg (106.7 KB, 9 views)
jam68 is offline   Reply With Quote
Old   February 11, 2017, 18:05
Joseph Murray
Here is the error I get when I run the plot over time:
p, li { white-space: pre-wrap; } ERROR: In /home/jam68/OpenFOAM/ThirdParty-2.4.0/ParaView-4.1.0/VTK/Common/DataModel/vtkTable.cxx, line 353
vtkTable (0x20ff36f0): Column "T_C" must have 25 rows, but has 1.
At this point I am up to 25 time steps. I opened up the OpenFoam simulation in paraview. I looked at the grid temperature over time in K. All looks good. I add a spreadsheet view and select 5 arbitrary points. I then add a calculator and create a new point variable called T_C which is T - 273.15. When I step through in time the table has a new column for T_C and it looks correct for the 5 points I selected. Not that in the spreadsheet view I have selected show only selected points to make the view manageable. So alls is good.
I think go to the Plot Over Time icon on paraview and select it. It crunches for a while and then pops up the error above. When I look at the plot over time I can only get the original T in K.
Any suggestions?
Thanks,
Joe.
calculator, data filter, plot over time
Thread Tools
Trackbacks are On
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
AMI speed performance danny123 OpenFOAM 19 October 24, 2012 07:44
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
