[OpenFOAM] How to run a blockMeshDict file in paraview |
March 27, 2017, 06:33 |
Mustapha Khalifa
We are currently working on a project, where we have to place sensors in a water pipe. We wanted to simulate the background information (water velocity and pressure), to see its impact on our sensors. I am a master student in Communication Engineering, so my knowledge in CFD is very limited. In this link: http://www.bankras.org/projects/open...foam/#more-309 you can download a Python code which outputs the the blockMeshDict file of few examples, we are interested in the first example in the link. I tried to run the blockMeshDict file using openFoam/paraview and Helyx os but I am not completely sure how to do it. Help would be highly appreciated. Regards, Mustapha |
April 11, 2017, 16:41 |
Daniel P. Combest
Mustapha,
First of all, welcome to the forum. In order to create a mesh from a blockMeshDict file in HELYX-OS, you can simply:
See the attached image with the result form your first link. I hope this helps. Last edited by chegdan; April 25, 2017 at 16:17. Reason: spelling |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
