[OpenFOAM] Using python script for automatic post processing of openFoam |
June 14, 2017, 10:54 |
Rep Power: 8 |
I'm having some problems with the automation of the post processing of my openFoam case.. 1) can't run python script with parafoam but can open my openFoam case 2) can run python script with paraview but can't open my openFoam case 3) I dont know how to fully automate my script i just know how to use: tool-->python shell is there a way to only use a script that: open paraview -> do stuff with python shell -> close paraview Thanx! |
June 14, 2017, 12:42 |
Joshua
Rep Power: 9 |
Have you tried running the script using pvpython?
You should be able to copy and paste your script into the python shell. Joshua |
June 14, 2017, 12:50 |
Rep Power: 8 |
tool -> python shell is greyed in parafoam so i can't use it..
June 14, 2017, 12:52 |
Joshua
Rep Power: 9 |
June 14, 2017, 13:03 |
Rep Power: 8 |
paraFoam 4.4.0 64bits Linux
June 14, 2017, 13:32 |
Joshua
Rep Power: 9 |
June 15, 2017, 05:22 |
Rep Power: 8 |
What's the difference between pvpython and python script?
I have use Cmake to put PARAVIEW_ENABLE_PYTHON = ON but python script is still greyed When i launch my script from the bash: paraFoam --script=parapy04.py I get an error message : Python support not enabled. Cannot run python scripts. Last edited by vPaquet; June 15, 2017 at 08:58. |
June 15, 2017, 09:09 |
Joshua
Rep Power: 9 |
Say you have script.py
If you run "python script.py" then python is used to run the script. If you do "pvpython script.py" then you use the paraview version of python that already has certain modules loaded into it. On the other hand, pvbatch is the parallel version of pvpython. Joshua |
June 15, 2017, 09:21 |
#9 |
Joshua
Rep Power: 9 |
June 15, 2017, 09:52 |
#10 |
Rep Power: 8 |
Yea I have seen this post but the problem is that I have is that paraview can't open my openFoam case correctly (only take 1/4 of the time steps and mix them up), but paraview have no problems running scripts.
So I use the paraview that was installed with openFoam (it can open my case without problems) but paraFoam cant run python scripts.. I have follow these steps to try to solve the situation but i didnt work: https://www.paraview.org/Wiki/ParaVi...iew_With_CMake Reistalling paraFoam seems like a pretty intricate task, it's all mixed up in OF files! |
June 15, 2017, 09:59 |
#11 |
Joshua
Rep Power: 9 |
Try installing the newest version of paraview 5.3, 5.2 also works well. Either way they have more filters and options then version 4.4.
Joshua |
June 20, 2017, 07:32 |
#12 |
Rep Power: 8 |
Now i have the version 5.4 of paraview installed but still got the same problem.
December 16, 2021, 03:30 |
#13 |
Asmaa
Rep Power: 10 |
Please check this video, the automation in paraview is well explained:
https://youtu.be/h6Y7HZR_SAI |
openfoam, parafoam, paraview, python |
PyFoam with Python Post Processing | godfatherBond | OpenFOAM Post-Processing | 0 | October 18, 2018 15:18 |
python script to create geometry for salome, and then mesh | 6863523 | Mesh Generation & Pre-Processing | 4 | March 18, 2017 09:00 |
Post processing in CFD Post or Fluent. | Blobs | OpenFOAM Post-Processing | 2 | June 26, 2016 07:23 |
Post processing from OpenFoam to Tecplot | danielec87 | Tecplot | 2 | August 14, 2012 14:19 |
CentFOAM Python Script Installation: Error | socon009 | OpenFOAM Installation | 2 | May 26, 2012 09:36 |
