Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing > OpenFOAM Paraview & paraFoam
Installation of ParaView on Ubuntu that exists in (Windows Subsystem Linux)
Old   July 9, 2017, 03:45
Default Installation of ParaView on Ubuntu that exists in (Windows Subsystem Linux)
Kasra
k.farnagh is on a distinguished road
Hi
I'm going to install ParaView on Ubuntu which installed through Windows Subsystem Linux (WSL).
So I've downloaded ParaView v5.4 from https://www.paraview.org/download/
and installed it. (I don't know what is 'nightly builds' in that link so I ignor them)
Further more, I've followed 'Enabling Graphical Applications' that exist in https://openfoam.org/download/windows-10/
I could finally ran a case with openfoam but when I want to apply paraview below error appears:
kasra@Kasra-PC:/c/mnt/Users/kasra/tutorial/cavity$ paraFoam
ERROR: ParaView reader module library (PVFoamReader) does not exist
Please build the reader module before continuing:
    cd $WM_PROJECT_DIR/applications/utilities/postProcessing/graphics/PVReaders
    ./Allwclean
    ./Allwmake
Using the native VTK/OpenFOAM reader instead
/opt/OpenFOAM/OpenFOAM-v1706/bin/paraFoam: 317: /opt/OpenFOAM/OpenFOAM-v1706/bin/paraFoam: paraview: not found
Would you please help me.
Sincerely Yours
k.farnagh is offline   Reply With Quote
Old   July 9, 2017, 09:03
Bruno Santos
wyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of light
Quick answer: To at least test if it works or not, you need to run the following command first:
export PATH=$PATH:/path/to/paraview/bin
Where you need to replace the path "/path/to/paraview/bin" with the actual path where you placed ParaView 5.4.0, including the path to its "bin" folder.
Old   July 9, 2017, 09:50
Kasra
Hi Dear Bruno
CFD online and Just Bruno you are the best. Thanks for reply.
As I mentioned early, the installation was performed in windows which caused that Linux kernel could not detect and apply it (as I recognized).
Then I enter
sudo apt install paraview
in bash to download it directly from Ubuntu.
With performing paraFoam the below message appears
    ./Allwclean
    ./Allwmake
The last line caused going everything well. If you think there are some problem hidden please tell me. Thank you again.
Sincerely Yours
Old   July 9, 2017, 19:24
Bruno Santos
Quick answers:
Sorry, but I didn't understand which line made it work properly?
I'm confused... first you stated that you downloaded ParaView 5.4.0 from paraview.org, but now you've gotten it via Ubuntu's apt?
Isn't the version available via apt an older version of ParaView?
Then again, if I understood you correctly, by using ParaView that was installed via apt, everything is working well, without the need to use the command I wrote in my previous comment.
Old   July 10, 2017, 01:48
Kasra
Hi Dear Bruno,
I haven't any problem now.
In first try I've installed paraview in windows via .exe file which downloaded from its official site. this approach not worked and I couldn't invoke paraview from bash.
In 2nd try I've installed paraview in (WSL) via apt command. this approach works properly.
In previous comment I tried to describe how the problem can be solved for who has same problem.
As you can see in previous comments, both approaches led to same error but in 2nd the native VTK/OpenFOAM reader module library used instead of paraview reader module (I don't know what I guess is correct or not).
The only question that remains is about error. Is it important to be solved?How can I solve it?
Thanks for your consideration
Sincerely Yours
Old   July 10, 2017, 07:02
Bruno Santos
Quick answers:
  1. The ParaView installation for Windows should be run on Windows. You would need to run it outside of bash.
  2. Within WSL:
    1. In order to not get the message about the "ParaView reader module", run paraFoam with the option "-builtin":
      paraFoam -builtin
    2. In order to not have to always write it, you can create an alias command at the end of the file "~ /.bashrc" like this:
      alias paraFoam='paraFoam -builtin'
      You will then either need to start a new terminal (command window) or run:
      source ~/.bashrc
  3. In order to use ParaView outside of WSL, you can run inside WSL the following command to create the file that is used by ParaView:
    paraFoam -touch -builtin
    "-touch" option will lead to the creation of a file with the name of the case and the file extension ".foam" that can be opened directly in ParaView.
Old   July 10, 2017, 08:31
Kasra
Hi Dear Bruno,
Thanks for great information that is useful.
Trackbacks are On
Installation ParaView for Windows version of openFOAM kasra karimi OpenFOAM Paraview & paraFoam 14 September 8, 2018 14:06
[foam-extend.org] FOAM on Windows, Linux and Mac hjasak OpenFOAM Installation 7 January 24, 2016 06:54
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message peteryuan OpenFOAM Installation 6 August 18, 2013 18:00
Thumbs up Successful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 9.04 AlanR OpenFOAM Installation 8 December 18, 2009 11:14
Linux to Windows (dual boot system) Alex Main CFD Forum 9 May 3, 2007 03:36
