Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Visualizing faces of an OpenFOAM mesh by ID in Paraview
Like Tree4Likes
  • 4 Post By ViktorKL
Old   September 7, 2017, 08:38
Default Visualizing faces of an OpenFOAM mesh by ID in Paraview
Timm Feigel
Timm Feigel is on a distinguished road
Dear all,
I need to locate a face in an OpenFOAM mesh by knowing its ID using Paraview. Although this seems possible for cells and points using the spread sheet option after splitting the view (see attached screenshot), it is not obvious to me how to do the same for faces.
Any help is highly appreciated, many thanks in advance.
Regards,
Timm
File Type: jpg Screenshot from 2017-09-07 14-22-05.jpg (199.6 KB, 135 views)
Timm Feigel is offline   Reply With Quote
Old   October 12, 2017, 20:15
Appu
ullal is on a distinguished road
Timm,
Did you figure out how to do this, i had exactly the same problem
ullal is offline   Reply With Quote
Old   October 13, 2017, 09:46
Timm Feigel
Originally Posted by ullal View Post
Timm,
Hello ullal!
No, unfortunately I haven't found a satisfying answer yet. In case I will, I will naturally post here for future readers.
Regards, Timm
Old   April 30, 2020, 05:19
Default Use topoSet and foamToVTK
Viktor Klüber
ViktorKL is on a distinguished road
If there is no other way you can create a faceSet with topoSet and visualize it as VTK-format.
In a topoSet dictionary, you need to provide the Face-IDs in a list by using the labelToFace-source as in the following example:
        name        zeroArea_f;
        type        faceSet;
        action      new;
        source      labelToFace;
        sourceInfo
            value
            339
            13055
After executing topoSet you can convert the resulting faceSet (named "zeroArea_f" in the example) into a VTK with the help of foamToVTK.
foamToVTK -faceSet zeroArea_f
It will create a .vtk-file with the faceSet's name in a VTK folder of your OpenFOAM case repository. You can open this file in paraview and visualize the faces.
This is a cumbersone workaround. However, it works when there is no other option.
ViktorKL is offline   Reply With Quote
face id, faces, parafoam, paraview, spreadsheet
[snappyHexMesh] Layers not growing at all zonda OpenFOAM Meshing & Mesh Conversion 12 June 6, 2020 11:28
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
