Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Reading field average in Paraview
Old   July 9, 2018, 10:25
Default Reading field average in Paraview
Alex
AlezXander is on a distinguished road
I have a DDES simulation using the field average function in controlDict, which gives averaged variables (UMean,pMean...) for desired timesteps, included in the timestep folder with all results of the simulation.
When I use paraFoam, the case and all timesteps are loaded. In properties, where all Mesh parts and Volume fields are listed to check the desired ones to load, I see all averaged variables and I can check them. However if I do a slice to see the averaged velocity contour of a certain time step UMean or any averaged variable are not listed as a possible variables, even if it has been already checked when loading the case.
Am I missing something? How can I load averaged variables to plot contours?
Thank you very much.
AlezXander is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 18:44
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
