[OpenFOAM] Extract Block with paraview native reader |
November 8, 2018, 03:53 |
Nejc
Rep Power: 9 |
I'm working with OpenFOAM on Windows Subsystem for Linux and therefore I have to use the separately installed ParaView from windows. When I use Extract Block filter none of the fields get passed on to the extracted block, I can only display it as solid color. It worked fine when I opened the case with paraFoam. Should I be doing the extract block or something else to get to my cellZone? The case is reconstructed and write format is ascii. Thanks! |
November 8, 2018, 08:19 |
Anton Kidess
Rep Power: 29 |
I'm guessing the native reader does not support cellZones. You can make a cellSet using topoSet, then use foamToVTK -cellSet XXX to create a VTK file which you can view with ParaView native.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
November 8, 2018, 08:34 |
Nejc
Rep Power: 9 |
Thanks for the reply.
What does "supports multiblock datasets" mean in the following description? https://kitware.github.io/paraview-d...OAMReader.html Anything to do with cell zones? |
August 29, 2021, 13:51 |
#4 | |
Mandeep Shetty
Rep Power: 10 |
August 30, 2021, 02:28 |
Nejc
Rep Power: 9 |
well i still don't know exactly what that means but if you want to load and view separate cellzones, yes, i figured it out:
Read zones and partial results hope that helps... |
cellzones, extract block, paraview, windows |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Parafoam - FATAL ERROR: ParaView reader module libraries do not exist | Amit_Pawarpawar | OpenFOAM Installation | 1 | August 25, 2014 10:31 |
[OpenFOAM] ParaView Reader %7c Visit | tj22 | ParaView | 16 | September 25, 2008 14:01 |
[OpenFOAM] OpenFOAM reader in the ParaView CVS | tj22 | ParaView | 16 | December 22, 2007 09:05 |
[OpenFOAM] Posted OpenFOAM native reader for ParaView3CVS | 7islands | ParaView | 0 | October 24, 2007 10:52 |
