January 16, 2009, 06:32 |
Average Velocity
Mat
how can i find average velocity of a particular time directory?plz do tell me as i am a beginner and using version 1.5 of OpenFOAM
January 16, 2009, 06:45 |
the utility patchAverag
Pattyn Eric
the utility patchAverage gives you the average of each velocity component Ux, Uy and Uz. To obtain these components from the vector U: foamCalc components U Then you calculate the average on one patch with the patchAvearge utility. patchAverage (U component) (patch name) -time (time directory you are interested in) Hope it can help you Eric |
January 16, 2009, 06:52 |
hi Eric thanks for your advice
Mat
It worked |
January 22, 2009, 00:18 |
hi,what is the procedure if in
Mat
hi,what is the procedure if in lid driven cavity, velocity varies between 1-2 m/s,what r the changes in 0 folder for U,if anyone knows then kindly inform me
June 1, 2009, 23:13 |
Hi Guys,
Is there any way to find average velocity from sampled data. I need to do this because of two reason.
Subodh |
Convective boundary condition using average velocity | bala_gk1988 | OpenFOAM Programming & Development | 1 | January 16, 2019 09:04 |
Average Rising Velocity as boundary condition | Floing | CFX | 11 | August 21, 2016 05:47 |
Monitoring Volume Average of Liquid Velocity Magnitude in a Bubble Column / Airlift | kevinlipps | OpenFOAM Post-Processing | 4 | May 19, 2016 05:59 |
Problem with time average tangential velocity in swirl flow. | lakhi | FLUENT | 5 | July 18, 2012 16:28 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
