Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] How to calculate Values for veriables for point
Old   September 26, 2008, 07:54
Default How to calculate Values for veriables for point
Vishal Jambhekar
vishal is on a distinguished road
Hi Foamars,
Can any one tell me how to calculate values for Pressure Velocity and density at specific point in mesh Values for veriables for point.
is there any tool in porefoam for this or any utility available.
Enjoy...
Vishal
Cheers,
Vishal Jambhekar...
"Simulate the way ahead......!!!"
vishal is offline   Reply With Quote
Old   September 26, 2008, 11:07
Default "sample" should be what you ne
Francesco Del Citto
fra76 is on a distinguished road
"sample" should be what you need.
You can find the source code and an example of input file in OpenFOAM-1.5/applications/utilities/postProcessing/sampling
Hope this helps,
Francesco
fra76 is offline   Reply With Quote
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
Mapping values from 2D mesh to 3D mesh boundary during runtime benk OpenFOAM Programming & Development 1 June 13, 2014 02:39
cell values vs node values reversemermaid FLUENT 0 March 13, 2014 18:06
Numerical errors in nested domain with pre-calculated boundary values Arnoldinho OpenFOAM Running, Solving & CFD 3 April 4, 2012 10:31
[ANSYS Meshing] Give me some simple formula for to calculate min & max size values using scaling pandu ANSYS Meshing & Geometry 2 June 6, 2011 11:35
