September 24, 2006, 20:28 |
Postprocessing with Fluent
Hello
I am trying to post-process the data from icoFoam/cavity in Fluent. When I run the foamMeshToFLuent script it generates a cavity.msh file but Fluent doesn't read it. it gives the following error message: Reading :"/home/li077/Gambit/cavity.msh" Error: File has wrong dimensions(3) Error object: #f When I try to execute foamDataToFluent I get the following message: Time = 0.5 --> FOAM FATAL IO ERROR : cannot open file file: /home/li077/OpenFOAM/li077-1.3/run/tutorials/icoFoam/cavity/system/foamDataToFlu entDict at line 0. From function regIOobject::readStream(const word&) in file db/regIOobject/regIOobjectRead.C at line 68. FOAM exiting Any advice? Shuo |
February 2, 2008, 08:30 |
hello
I export data to fluent
hello
I export data to fluent by foamDataToFluent. In fluent I can see velocity, tempreture ,... but secondary parameter such that wall flux and wall shear stress not caculate in fluent. in the other hand fluent caculate secondary parameter for data file that solved by fluent but don't caculate this parameter for data file that exported from foam. What I can with this problem? my soler is buoyantSimpleFoam. thanks very lot |
February 5, 2008, 09:29 |
you could try to compute a sin
nicolas
you could try to compute a single iteration in fluent.
February 5, 2008, 09:30 |
and the first error (1st post)
nicolas
and the first error (1st post) comes from the fact that the mesh is 3D and not 2D.
September 18, 2008, 01:14 |
Hi Shuo Li
In your case che
Ameya Durve
Hi Shuo Li
In your case check whether you have foamDataToFluentDict file in system folder of your case. If you dont then copy the file from tutorials/icoFoam/elbow/system. It may solve your problem |
September 9, 2011, 06:25 |
hello Everyone
how to case file of openfoam run in fluent because when i go for foamDataToFluent then it convert all the data in .dat file but without case file i cant run the programe in fluent so what can i do?
June 27, 2016, 17:41 |
Rep Power: 10 |
Hi Jignesh
I have your problem,do you solve it? |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 16:41 |
fluent journal files - speedup your postprocessing | warlock | FLUENT | 0 | March 8, 2006 23:36 |
