[OpenFOAM] Postprocessing a specific boundary |
March 16, 2007, 09:23 |
Christian Lindbäck
Rep Power: 17 |
To postprocess my data I would need help to do the following:
1) I want to write the following to separate text files: i) The pressure data of each wall cell face of a specific boundary. ii) The coordinates of the wall faces in that boundary. iii) The area of each wall face. 2) I want to sum the wall pressure times face area of the specific boundary. How can I do this without using the text files created in (1)? I'm a rookie using OpenFOAM. This means you can't be too clear when answering my questions. All answers, even if you answer only one of my questions, are very welcome. Best regards, Christian |
March 16, 2007, 09:42 |
Should be easy.
- make an o
Hrvoje Jasak
Rep Power: 33 |
Should be easy.
- make an object of type OFstream, giving it the file name - pick out the patch you want to write in (I will call its index patchID) - write: Before main(), add: #include "OFstream.H" and at the point where you want to write: OFstream of("myFile.txt"); of << p.boundaryField()[patchID] << endl; of << mesh.C().boundaryField()[patchID] << endl; of << mesh.Sf().boundaryField()[patchID] << endl; If you want each into a separate file, make yourself multiple OFstream objects For the sum, do: vector sumForce = sum(p.boundaryField()[patchID]*mesh.Sf().boundaryField()[patchID]); Could it be easier? Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
March 16, 2007, 10:19 |
Thank you very much. First of
Christian Lindbäck
Rep Power: 17 |
Thank you very much. First of all I wonder where am I supposed to learn about how to do the things you just taught me?
Now to some questions regarding your reply: 1) In which file am I supposed to insert the lines you suggested me? 2) Let's talk about writing the wall face pressure data, wall face coordinates and size. How is each value connected to a specific wall face? Is there a column next to the data value column saying face no 2 of cell no 21345? I mean, I need to be able to keep track of which face area that belongs to which face pressure. The values will of course be listed in the same order, but assume I want to pick a specific cell face by its number. 3) Why is the data type vector in "vector sumForce = sum(..."? The answer will be a real value. I haven't been using C++ before. 4) Assume instead I want to find data values of the cells of the boundary (not the faces). What command will I use then? 5) I've created a cut plane through my boundary where a do a contour plot. Now I simply want to step through my time steps and create an animation. How do you suggest me to do this? Should I save images and use some other software to create an animation (which?) or should I create an .mp2 animation right away? I want to run the animation on a Windows system. Best regards, Christian |
March 16, 2007, 12:55 |
...where am I supposed to lear
Hrvoje Jasak
Rep Power: 33 |
...where am I supposed to learn...
The obvious answer is to look for examples in OpenFOAM, because I or other people must have done something similar already. If you need to be better at this, you can attend some training, come to the Workshop or (especially if you are working in a company using OF for commercial work) get some OpenFOAM support to help you produce quality results on time. Feel free to send me an E-mail if you want to talk about this. Anyway, the level of things you are looking for is still easy: so, play, try to guess, learn by example etc. It's not that hard, really. How is each value connected... In the example, I am writing the values for all boundary faces. Face centres, face areas and everything else will be ordered in the same manner. Thus the first pressure belongs to the first face and the first face centre - all the lists are ordered the same. data type vector in "vector sumForce = sum(..."... Physics, physics! Pressure is a scalar and it acts normal to the surface, right? Therefore, force is a vector because it depends on the orientation of the surface - you really *should* know this. ...find data values of the cells... The cell values are in p.internalField(). If you ask the patch for faceCells(), it will give you a cell index next to each boundary face. You know the rest... ...and create an animation... Create a series of images, and convert them into an animation using some package. I am using convert on Linux, which is a part of ImageMagick and make an mpeg video. Enough for now I think... Hrv
March 22, 2007, 02:26 |
I see. My first question conce
Christian Lindbäck
Rep Power: 17 |
I see. My first question concerned writing pressure data, coordinates and area of specific boundary faces to a file. I was given the lines necessary to do this. Now, I'm wondering the following:
1) Assume I'm running simpleFoam. I want to find a steady-state solution. Will I then, using the lines I was given, write a file at every iteration or only after the final iteration? How can I control this to achieve both scenarios? 2) Assume I'm running turbFoam. I'm solving a transient case. Will I then, using the lines I was given, write a file at every time step or only after the final time step? How can I control this to achieve both scenarios? Best regards, Christian |
March 22, 2007, 02:39 |
You'll have to code it yoursel
Mattijs Janssens
Rep Power: 26 |
You'll have to code it yourself.
1) $FOAM_SOLVERS/incompressible/simpleFoam/simpleFoam.C 2)$FOAM_SOLVERS/incompressible/turbFoam/turbFoam.C |
March 30, 2007, 06:12 |
Sorry the link didnt lead wher
Erik Arlemark
Rep Power: 17 |
Sorry the link didnt lead where I thought it would.
Here is a thread I saved from the forum: Continuity Eq: div(U) = 0 and with source term: div(U) = S Discretised momentum eq. A*U = H - grad(p) -> U = H/A -(1/A)*grad(p) = Ustar - (1/A)*grad(p) H/A is the momentum-predictor value of U, ie Ustar. if we insert this in the continuity eq. it yields div(U) = div(Ustar - (1/A)*grad(p)) = S -> div(Ustar) - laplacian(1/A, p) = S or laplacian(1/A, p) = -S + div(phi) where phi is Ustar evaluated on faces. have a look at icoFoam and you will easily see where to insert S. /Erik |
July 12, 2007, 07:34 |
I'm running parallel and use p
Christian Lindbäck
Rep Power: 17 |
I'm running parallel and use p.boundaryField()[patchID] to access the pressure of each wall cell face of a certain boundary. I write this data to a file. However, it ends up in all processor directories, being zero in the partitions not containing my boundary. How do you suggest me to make the code write this data only if the boundary of interest is in the current partition (processor directory)?
Best regards, Christian Svensson |
July 12, 2007, 09:22 |
Just a guess (havn't looked at
#9 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Just a guess (havn't looked at the source). As far as I remember the probes-functionObject collects all the data on the first processor and writes it there. I guess that would be even more convenient for you. Have a look at that source, it might give you some hints.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
June 10, 2008, 06:26 |
hi all,
i want to check that
#10 |
davey david
Rep Power: 17 |
hi all,
i want to check that mass is conserved in my simulation?so i want to get the data for my inlet and outlet.can someone please help here. cheers davey |
June 10, 2008, 07:05 |
Hi Davey
Without trying it,
#11 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Davey
Without trying it, I believe something like this should work: scalar checkMass(0.0); forAll(phi.boundaryField(),patchID) { checkMass += sum(phi.boundaryField()[patchID]); } Info << "checkMass: " << checkMass << endl; Best regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
June 10, 2008, 07:18 |
hi all,
managed to fix it.sor
#12 |
davey david
Rep Power: 17 |
hi all,
managed to fix it.sorry i was a bit impatient in scanning the forum! thanks anyway davey |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
