Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Mesh
Old   September 29, 2006, 01:06
Default Mesh
shuo
Hi
is there a way of displaying the boundary patches of the meshed geometry in Paraview so that you know which physical boundaries you are modifying?
Shuo
Old   September 29, 2006, 02:46
Default A similar topic was posted jus
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
A similar topic was posted just few days ago:
Displaying solid boundaries
It says: use Filters->ExtractParts
dmoroian is offline   Reply With Quote
Old   September 29, 2006, 02:52
Default - "Extract Parts" in the "Filt
Assistant Moderator
Bernhard Gschaider
- "Extract Parts" in the "Filter"-menu is what you're thinking of.
- Or you're using the "region"-Subpane of the "Parameters"-tab of the data
- Propably there is at least a third way to do it in paraview that I don't know about
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 29, 2006, 21:14
Default Mesh
shuo
Hi
Thanks for the response. What I meant to say is there a way of displaying the names of the boundary conditions on the mesh like in Fluent. With a complex mesh it is hard to know exactly where the boundary conditions are being applied
Regards
SHuo
Old   October 2, 2006, 04:59
Default I don't know of any way to do
Mattijs Janssens
mattijs is on a distinguished road
I don't know of any way to do this. I agree it would be a very useful feature to have though. Anyone with Paraview/VTK knowledge?
mattijs is offline   Reply With Quote
Old   October 2, 2006, 09:54
Default This is extremely basic but it
theof
This is extremely basic but it can be done by hand for rather simple geometries using a 3D text source, and playing with the display option. As an alternative you can still write the name of your boundary in the Selection Window. Highlight your surface, then you can change the "Label". HTH
ThF
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
