May 12, 2006, 12:32 |
Cell Types and Face Layout
Terry Jordan
Since the file format has changed to owner/neighbor format, does the face numbering for the cells still hold true? Seems not to. I am looking at a dataset with all hexahedrons. And if I grab the faces for the first cell (0) the order of the faces does not correspond to the face numbering in the documentation. Also does not seem to hold true for the next. Can anyone provide me some assistance with the ordering of the faces? I am trying reconstruct the cell in VTK.
May 12, 2006, 13:11 |
Why don't you just the mesh to
Hrvoje Jasak
Rep Power: 33 |
Why don't you just the mesh to give you the shapes?
Hrv OpenFOAM-1.3/src/OpenFOAM/meshes/primitiveMesh/primitiveMesh.H //- Calculate cell shapes void calcCellShapes() const;
May 12, 2006, 13:56 |
I have figured it out. Thanks
Terry Jordan
I have figured it out. Thanks anyways.
May 15, 2006, 04:10 |
Also: foamToVTK/vtkTopo.C to s
Mattijs Janssens
Rep Power: 26 |
Also: foamToVTK/vtkTopo.C to see how cellShapes are converted into VTK shapes.
May 15, 2006, 14:15 |
Thanks but I still am not find
Terry Jordan
Thanks but I still am not finding how the faces from a faces file are layed out. I was using the bubbleColumn example. In the first row of hexes, the normal for the owner faces point into the cell while the faces from the neigbor cells point out.
when I move on to the next row it is the inverse. In Vtk the points need to be in a certain order to look correct which seems to corresponds to the point layout for foam on the cell type doc. But I cant seem to find the rhyme or reason of how foam lays out the faces. Thanks. |
May 15, 2006, 14:21 |
Try this:
~/.OpenFOAM-1.3/c
Hrvoje Jasak
Rep Power: 33 |
Try this:
~/.OpenFOAM-1.3/cellModels So, for a hex: hex { index 3; numberOfPoints 8; faces 6 ( 4(0 4 7 3) // x-min 4(1 2 6 5) // x-max 4(0 1 5 4) // y-min 4(3 7 6 2) // y-max 4(0 3 2 1) // z-min 4(4 5 6 7) // z-max ); edges 12 ( (0 1) // x-direction (3 2) (7 6) (4 5) (0 3) // y-direction (4 7) (5 6) (1 2) (0 4) // z-direction (1 5) (2 6) (3 7) ); } A tet is: tet { index 7; numberOfPoints 4; faces 4 ( 3(1 2 3) 3(0 3 2) 3(0 1 3) 3(0 2 1) ); edges 6 ( (0 1) (0 2) (0 3) (3 1) (1 2) (3 2) ); } I hope you can read this. Hrv
May 17, 2006, 13:05 |
I now have an algorithm that w
Terry Jordan
I now have an algorithm that works. Thanks anyways.
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 04:17 |
[Commercial meshers] Porous Jump creation problem | mulfal | OpenFOAM Meshing & Mesh Conversion | 4 | December 9, 2013 11:59 |
[GAMBIT] Problem with interior faces | miro2000 | ANSYS Meshing & Geometry | 11 | August 24, 2013 14:00 |
WARNING: non-positive face area exist. | Alan | Main CFD Forum | 4 | August 17, 2006 07:33 |
Gambit bug??? Face vertex types | Friederike | FLUENT | 5 | April 19, 2005 19:06 |
