Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] ParaFoam conflicting version of paraview
Old   May 11, 2006, 07:26
Default ParaFoam conflicting version of paraview
Xavier Ponticq
xponticq is on a distinguished road
Hi
I've installed OpenFOAM v1.3 for linux recently on my computer and all the related packages following the installation notes. The installation seems to be ok, FoamX and the solver running perfectly. However I've got a problem with the parafoam application. When I use parafoam, it doesn't launch the paraview version bundled with OpenFOAM but an older version installed previously on my computer, and then crashes because of VTK errors in the driver. I don't know if it is a problem due to environment variables because the cshrc file is source correctly. If anyone got an idea ...
Xavier
xponticq is offline   Reply With Quote
Old   May 11, 2006, 08:24
Default The problem is that the OpenFO
Assistant Moderator
Bernhard Gschaider
The problem is that the OpenFOAM-xxhrc-files are too humble: they append the OpenFOAM-paraview-implementation to the PATH-variable (instead of prepend it so that it is found earlier than the legacy-version).
Look for the line that says:
export PATH=$(PATH):/path/to/OpenFOAM/paraview
in the apps/paraview/xxhrc and change it to
export PATH=/path/to/OpenFOAM/paraview:$(PATH)
(or something similar for cshrc) and do the same for the LD_LIBRARY_PATH-variable. Then the right paraview is found earlier.
It has already been talked about and one of these days somebody should write a bug report about it ....
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 11, 2006, 09:17
Default Thanks a lot Bernhard, everyth
Xavier Ponticq
Thanks a lot Bernhard, everything works just fine now
Old   May 16, 2006, 12:52
Default >The problem is that the OpenF
Mattijs Janssens
mattijs is on a distinguished road
Not anymore. We'll prepend the paraview stuff to the path. Thanks.
mattijs is offline   Reply With Quote
[OpenFOAM] configuring paraFoam to use a different version of Paraview MikeWallis ParaView 5 May 6, 2021 14:05
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] u2berggeist OpenFOAM Installation 2 July 2, 2018 17:03
paraFoam error on dual version install ecbmxer OpenFOAM Installation 10 August 9, 2012 11:23
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
[OpenFOAM] ParaView patch visualisation error in Development version philippose ParaView 17 March 26, 2007 06:45
