Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] File Format certainity
Old   April 11, 2006, 13:14
Default File Format certainity
Terry Jordan
tj22 is on a distinguished road
I am looking at adding a reader to paraview for OpenFoam files. I wanted to find out how set the file format is. Is there any talk of changing the file format soon or even later?
Thanks.
tj22 is offline   Reply With Quote
Old   April 11, 2006, 13:41
Default Will your reader be any differ
Mattijs Janssens
mattijs is on a distinguished road
Will your reader be any different from the paraFoam one?
There are no plans to change the file format any time soon. But if you use OpenFOAM functionality to read the mesh all this will be shielded from you.
Mattijs
mattijs is offline   Reply With Quote
Old   April 11, 2006, 13:48
Default Nothing is set in stone but I
Terry Jordan
Nothing is set in stone but I am looking at foregoing using the OpenFOAM package to read the files.
Old   April 11, 2006, 13:56
Default Not directly related: do you k
Mattijs Janssens
Not directly related: do you know whether VTK can handle polyhedral cells directly? We currently have to decompose anything which is more complex than a hex which is annoying.
Mattijs
Old   April 11, 2006, 14:47
Default You may want to take a look at
Terry Jordan
You may want to take a look at convexpointset. That should work although you may take a performance hit.
Old   April 12, 2006, 11:17
Default I was looking at you cell type
Terry Jordan
I was looking at you cell types and I see the following correlation in VTK:
Hexahedron vtkHexahedron
Wedge vtkConvexPointSet
Prism vtkWedge
Pyramid vtkPyramid
Tetrahedon vtkTetrahedon
Tet-Wedge vtkConvexPointSet
Old   April 12, 2006, 11:27
Default We use vtkTetrahedon vtkPyrami
Mattijs Janssens
We use vtkTetrahedon vtkPyramid vtkWedge vtkHexahedron
I tried convexPointSet and it does not do what I want. It triangulates a convex point cloud but does not see the difference between internal and external faces of the mesh so it shows all faces which makes it very slow.
What I would like is a generic vtk cell shape which implements all the needed functionality (cutting planes, derivatives etc) by on-the-fly decomposition.
Old   April 12, 2006, 11:30
Default Is it possible for you to add
Terry Jordan
Is it possible for you to add an empty .Foam file to the topmost directory in the case by default? This would call for adding one more file to the openfoam format but would not cause a need for changing any other files. It would just be a place holder for an entry point for readers as you did within your parafoam script. It could also be used to store some header info if desired at a later data.
How feasible would it be for you to add that?
Old   April 12, 2006, 12:10
Default Sorry, no intention of doing s
Mattijs Janssens
Sorry, no intention of doing so at the moment.
- you could change your paraFoam script not to delete the .foam file.
- you could set the extension of 'foam' files to be 'controlDict' instead of '.foam' (if vtk allows this) and click on the system/controlDict
Old   April 12, 2006, 13:10
Default "- you could set the extension
Terry Jordan
"- you could set the extension of 'foam' files to be 'controlDict' instead of '.foam' (if vtk allows this) and click on the system/controlDict" - this was one idea I had.
"- you could change your paraFoam script not to delete the .foam file." - I am planning on writing my own readers for paraview.
I figured I would give it a shot and ask if you could, no big deal I will work around it.
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
