Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Could anyone please help me in running the paraview in my Ubuntu system
Old   February 3, 2006, 11:23
Default Could anyone please help me in running the paraview in my Ubuntu system
chanduksekhar
Hi all I am trying to run a tutorial called cavity
in icoFOAM directory and when I type
$ paraFoam $FOAM_RUN/tutorials/icoFoam cavity
or
$ paraFoam /project/foam/OpenFOAM/foam-1.2/run/tutorials/icoFoam cavity
I am getting
line 57: paraview: command not found
what can I do to run my paraFOAM can you all please help me because I am learning the OpenFOAM to complete my masters project in time.
Thanks all
chandra s kothamasu
Old   February 3, 2006, 11:30
Default > line 57: paraview: command n
stefan
stefanke is on a distinguished road
source your shell (for details consult the readme file of OpenFoam). After doing this your system should be able to find paraview (if you installed it correctly)
stefanke is offline   Reply With Quote
Old   February 6, 2006, 09:13
Default thanks for the help i will con
chanduksekhar
thanks for the help i will consult my supervisor regarding that.
thanks once again stefan
[OpenFOAM] Problem on multicore in running paraview foamF ParaView 5 April 23, 2019 15:57
Different running efficiency under different Ubuntu system? wdx_cfd OpenFOAM Running, Solving & CFD 0 March 27, 2019 21:10
[OpenFOAM.org] (Script)OpenFOAM 2.3.0 and Paraview for Ubuntu 14.04 p0kerus OpenFOAM Installation 2 December 2, 2014 07:54
Paraview running slowly after installation of OF 2.3 on Ubuntu 14 marluc OpenFOAM Installation 11 June 9, 2014 08:33
running Fluent on a DUAL CORE system Ralf Schmidt FLUENT 3 June 20, 2006 10:21
