[OpenFOAM] Running paraFoam on remote machine
Old   August 9, 2005, 14:22
Default Running paraFoam on remote machine
makh
I installed and ran paraFoam as in:
http://www.opencfd.co.uk/openfoam/li...tml#linuxAMD64
I also did the same on remote cluster but I recompiled the code using Allwmake. I ran the code no problem. But when I try to start paraFoam on the case result, I get the following error:
ParaView error: InitializeTcl failed
Tk_Init error: no display name and no $DISPLAY environment variable
If I try to run it from other node except the main one, I get the following error:
paraview: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
I tried to look for libGL.so, I could not find it neither on the remote nor local version that is still working.
Thanks,
Marwan
Old   August 12, 2005, 14:42
Default Problem solved.
makh
Problem solved.
[TUTORIAL] Run fluent on distributed memory with 2 windows 7 64 bit machines ghost82 FLUENT 54 February 9, 2022 03:32
Running server on remote machine harry123 STAR-CCM+ 0 April 25, 2016 03:45
Remote Standalone Machine for CFD victorz Main CFD Forum 3 February 12, 2012 08:42
Random machine freezes when running several OpenFoam jobs simultaneously 2bias OpenFOAM Installation 5 July 2, 2010 07:40
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
