Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Display internal field together with boundaries
Like Tree1Likes
  • 1 Post By santos
Old   June 10, 2009, 06:38
Default Display internal field together with boundaries
Gunnar Werte
gunnar is on a distinguished road
Dear Openfoam community,
I am new to this amazing CFD tool, and have a (maybe) stupid question about paraFoam.
How can I display both boundary patches and internal field from an Openfoam calculation? For example pressure contours in a pipe from an icoFoam result together with the pipe surface (clipped, of course, so that it doesn't hide the contours).
Do I have to load the Openfoam source twice and in one source enable only the internal field, and in the other enable only the boundaries? I expect this will be very inefficient for large data sets. Is it possible to put a kind of T-piece into the pipeline, basically branching the Openfoam source so that I can work on the internal field in one branch and on the boundaries in the other branch?
I hope my question is more or less clear. If you think the answer is trivial, please give a short step-by-step explanation, because I couldn't find a satisfying solution.
Gunnar
gunnar is offline   Reply With Quote
Old   June 11, 2009, 05:52
Gunnar Werte
For better illustration of my question please have a look at the attached screenshot.
The pipeline browser shows two cavity.OpenFOAM entries.
The first one is used to display the pressure field on a cutplane.
The second one (visible in the object inspector) is used to display the walls in a solid color.
If I wanted to display more regions with different display parameters each, I can't believe that adding another cavity.OpenFOAM for each reagion is the way to go?
How can I extract either the movingWall and fixedWalls or the internalMesh from a single cavity.OpenFOAM (where all regions are enabled) in order to display each extraction with different parameters?
Gunnar
Old   June 25, 2009, 04:21
Gunnar Werte
Does nobody have a solution how to display different parts (boundaries and internal mesh) of the openfoam output with different properties (solid color, different variables) without loading the complete output several times for each output?
My actual calculation (not the example in the previous post) is so large that I cannot open it more than once in paraFoam. Currently I have to switch between either displaying either the internal mesh or parts of the boundaries. This is time consuming, and the separate displays are difficult to interprete.
Gunnar
Old   June 25, 2009, 04:49
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
I think you can use the 'Extract block' filter in Paraview.
Regards,
Jose Santos
bjnieuwboer likes this.
santos is offline   Reply With Quote
Old   June 25, 2009, 12:00
Gunnar Werte
perfect! Extract Block is what I needed.
creating an internal field? maybee OpenFOAM Programming & Development 2 February 4, 2021 17:15
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
mapping Data to internal field cyln OpenFOAM Running, Solving & CFD 1 April 10, 2018 05:19
Omega.correctBoundaryConditions() changes the internal field values? ripperjack OpenFOAM Programming & Development 2 January 26, 2017 10:55
Display internal field together with boundaries in paraFoam gunnar OpenFOAM Post-Processing 0 June 10, 2009 05:39
