October 4, 2009, 14:26 |
surfaceScalarField in paraFoam
Daniel Riemann
how can I display a surfaceScalarField in paraFoam? I have a surfaceScalarField F written in each time step. But when I open the case with paraFoam, the variable F is not available. If paraFoam can't read surfaceScalarFields, I could as well work with the field values interpolated onto a volScalarField. But I don't find an interpolation function for this - only the opposite direction (volScalarField to surfaceScalarField) seems to exist. Can you tell me the required commands to interpolate a surfaceScalarField to a volScalarField? Thanks Daniel |
October 5, 2009, 02:08 |
Alberto Passalacqua
Rep Power: 36 |
Simply do:
foamToVTK -surfaceFields in your case directory, then use paraview to show the surfacefield with the glyph function. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
[OpenFOAM] Unable to launch parafoam & | boonhow | ParaView | 5 | March 23, 2022 08:09 |
Upwind Gradient Not Recognizing surfaceScalarField | MajidHagh | OpenFOAM | 2 | October 30, 2019 11:58 |
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] | u2berggeist | OpenFOAM Installation | 2 | July 2, 2018 17:03 |
[OpenFOAM] How to use paraFoam on a cluster | andreas | ParaView | 1 | March 6, 2013 17:11 |
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY | raketenmaid | ParaView | 4 | February 5, 2013 05:20 |
