February 12, 2010, 02:05 |
paraFoam crashing on Ubuntu 9.10
subash
Rep Power: 16 |
Hi
I have installed openFOAM 1.6 on a ubuntu 9.10 machine with no compilation problems. The versions of Qt and paraFoam are 4.5.2 and 3.6.1. When the cavity problem was run, the first (blockMesh) and the second step(icoFoam) ran well without any problem. But when I tried to view the results by running paraFoam it asked to select a reader for the file, the application crashed as soon as the reader was selected throwing an exception which goes like this Read float past end of buffer Read float past end of buffer Read float past end of buffer Read float past end of buffer Qt has caught an exception thrown from an event handler. Throwing exceptions from an event handler is not supported in Qt. You must reimplement QApplication::notify() and catch all exceptions there. terminate called after throwing an instance of 'std::length_error' what(): basic_string::_S_create Aborted Please let me know how to overcome this error. |
February 12, 2010, 10:53 |
Rep Power: 16 |
Hi I had a similar problem.
This should help you, good luck You can read some hints, there: http://www.cfd-online.com/Forums/ope...ookbook-4.html Or simply try: apt-get install cmake cd $FOAM_UTILITIES/postProcessing/graphics/PV3FoamReader ./Allwclean ./Allwmake Or if it is not fixable: Use foamToVTK for your OpenFoam-Files, then you can open them as vtk with paraview. |
[OpenFOAM.org] OpenFOAM v5 on ubuntu 14.04 - Problem with ParaFoam | giorgos | OpenFOAM Installation | 2 | October 31, 2017 07:55 |
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY | raketenmaid | ParaView | 4 | February 5, 2013 05:20 |
Installation of OpenFOAM-1.6 on Ubuntu 9.10 | marval | OpenFOAM Installation | 2 | March 17, 2010 08:33 |
Peoblem with paraview on ubuntu 9.10 machine | nabeels | OpenFOAM Bugs | 0 | December 26, 2009 15:15 |
[OpenFOAM] Problem with parafoam on ubuntu 9.10 machine | nabeels | ParaView | 0 | December 25, 2009 23:12 |
