Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] gliph display
Old   July 7, 2010, 04:03
Default gliph display
vaina74 is on a distinguished road
Hi everybody.
I have a problem. In order to display U vectors (simpleFoam case) I always used Cell Centers and Gliph filters, as in cavity tutorial. Today I obtain this message:
$ paraFoam
created temporary 'tandem_blade_7_0_better.OpenFOAM'
ERROR: In /OpenFOAM/ThirdParty-1.6.x/paraview-3.6.1/VTK/Common/vtkDataArrayTemplate.txx, line 142
vtkFloatArray (0x1c3fa530): Unable to allocate 155116653 elements of size 4 bytes.
terminate called after throwing an instance of 'std::bad_alloc'
what():  std::bad_alloc
/OpenFOAM/OpenFOAM-1.6.x/bin/paraFoam: line 111: 27881 Aborted                 paraview --data="$caseFile"
Is it a memory problem?
vaina74 is offline   Reply With Quote
Old   July 8, 2010, 06:50
Retired Super Moderator
Bruno Santos
Hi Maurizio, I see you're using OpenFOAM very successfully
I've come across that very same issue a couple of weeks ago. Basically, that message means that the machine doesn't have about 600MB of contiguous free RAM (and Swap doesn't count)!
But there is a rather simple solution, without resorting to buying more RAM: you must change the resolution of the glyphs! If you change the resolution for each arrow to have less triangles on the head and the body, then you can represent a lot more arrows in a single scene!
The exact names of the relevant resolutions of the Arrow are:
  • Tip Resolution
  • Shaft Resolution
The other values don't affect the amount of RAM required for generating the glyphs/arrows!
Best regards,
Bruno
Old   July 8, 2010, 10:17
Thank you, Bruno. I thought Ubuntu and 4 Gb RAM were enough...
Your hint works and now I can get my smart coloured gliphs and streamlines
You seem to have a solution for every section of the forum
Cheers,
Maurizio
Old   July 8, 2010, 10:59
Bruno Santos
I'm glad it worked As someone once said:
if you only have lemons, make lemonade
Alas I'm only somewhat fluent in installing OpenFOAM, and dabble with post-processing (with ParaView only). Everything else in the middle is still one seriously giant black box
Best regards,
Bruno
[Other] paraFoam error scybchenjun OpenFOAM Meshing & Mesh Conversion 0 May 11, 2016 23:25
Scheme Executable Terminating Prematurely ec44 Fluent UDF and Scheme Programming 1 April 6, 2015 03:34
[OpenFOAM] Xlib: extension "GLX" missing on display goldbeard ParaView 5 March 24, 2013 13:12
errors when installing openfoam2.1 on ubuntu12.o4 hewei OpenFOAM Installation 5 May 29, 2012 07:43
free surface display carno Siemens 4 October 7, 2005 01:03
