deniggo |
August 26, 2010 06:07 |
paraview displays strange geometry
I'm using OF 1.7 on OpenSuse 11.3.
OF is doing well. But paraFoam (v. 3.8.0) leads to strange geometry and missing result data (e.g. p,k, epsilon... in rasinterfoam). At least, it is my geometry.
The conversion via foamToVTK works, but it's a second step and needs more disk space.
Maybe the problem is in bashrc?!
Thanks for help,
Nico
# clean the PATH
cleaned=`$WM_PROJECT_DIR/bin/foamCleanPath "$PATH" "$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER/cmake- $WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER/paraview-"` && PATH="$cleaned"
# determine the cmake to be used
unset CMAKE_HOME
for cmake in cmake-2.8.1 cmake-2.8.0 cmake-2.6.4
do
cmake=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER/$cmake
if [ -r $cmake ]
then
export CMAKE_HOME=$cmake
export PATH=$CMAKE_HOME/bin:$PATH
break
fi
done
# set VERSION and MAJOR (version) variables
ParaView_VERSION=3.8.0
ParaView_MAJOR=unknown
# if needed, set MAJOR version to correspond to VERSION
# ParaView_MAJOR is "<digits>.<digits>" from ParaView_VERSION
case "$ParaView_VERSION" in
"$ParaView_MAJOR".* )
# version and major appear to correspond
[0-9]*)
# extract major from the version
ParaView_MAJOR=`echo $ParaView_VERSION | sed -e 's/^\([0-9][0-9]*\.[0-9][0-9]*\).*$/\1/'`
esac
export ParaView_VERSION ParaView_MAJOR
paraviewInstDir=$WM_THIRD_PARTY_DIR/paraview-$ParaView_VERSION
export ParaView_DIR=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER/paraview-$ParaView_VERSION
# set paths if binaries or source are present
if [ -r $ParaView_DIR -o -r $paraviewInstDir ]
then
export PATH=$ParaView_DIR/bin:$PATH
export LD_LIBRARY_PATH=$ParaView_DIR/lib/paraview-$ParaView_MAJOR:$LD_LIBRARY_PATH
export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-$ParaView_MAJOR
# add in python libraries if required
paraviewPython=$ParaView_DIR/Utilities/VTKPythonWrapping
if [ -r $paraviewPython ]
then
if [ "$PYTHONPATH" ]
then
export PYTHONPATH=$PYTHONPATH:$paraviewPython:$ParaView_DIR/lib/paraview-$ParaView_MAJOR
else
export PYTHONPATH=$paraviewPython:$ParaView_DIR/lib/paraview-$ParaView_MAJOR
fi
fi
else
unset PV_PLUGIN_PATH
fi
unset cleaned cmake paraviewInstDir paraviewPython
