[General] paraview - plotting difference to reference data |
August 30, 2010, 18:01 |
Joerg Wensch
I am using paraview 3.6.2. I compute time-dependent velocity data,
but these vary more rapidly in space than in time. Therefore, I want to plot the difference to a reference state in order to visualise the timedependent variation. I do not want to write out the differences as well as the data because this increases the amount of data a lot, I want to save just the timedependent data and the referencde state. How can I visualise the difference between the set of timedependent data v1,v2,... and the single reference state vRef? I have used the calculator to assign differrent names to the v-fields, then I used "group datasets" to join these, then a calculator is applied to compute the difference. paraview complains that I have not the right data. Is this problem known? I think the problem is that I have a set of data and building the difference with a single record seems to be not appropriate. Last edited by joewe; August 31, 2010 at 05:28. |
[General] Plotting data around a circle in ParaView | Eman. | ParaView | 0 | November 18, 2017 19:50 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Installing OpenFOAM-1.5-dev on a cluster | ZKM | OpenFOAM Installation | 4 | December 25, 2010 15:59 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
