[OpenFOAM] Paraview graphics window whited out |
February 24, 2011, 09:29 |
jeff osborne
Hello all,
I can use paraview fine but when I go to save state, and then re-open that state file, the graphics window is whited out and I cannot view anything. When I try and rotate the camera I can see graphics, but when I let go of the mouse it becomes whited out again. Any thoughts on this? Thanks Jeff |
February 24, 2011, 17:53 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Jeff,
The issue you are getting is very similar to the one described here: http://www.cfd-online.com/Forums/ope...-rotating.html The other possibility is that the version of ParaView you are using has a bug that only happens in certain scenarios. Check the solutions in the thread above and if those don't work, try using another version of ParaView. Best regards, Bruno
March 14, 2011, 13:15 |
jeff osborne
For all interested: The solution was that my graphics settings were messed up on my computer. If anyone has this issue try lowering your graphics resolution, that's what worked for me.
J |
Graphics card for Paraview | flotus1 | Hardware | 15 | January 27, 2019 13:22 |
[OpenFOAM.org] ParaView: Open File window gets bigger and bigger until it's impossible to press open | mn16mg | OpenFOAM Installation | 3 | January 10, 2019 11:17 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
How to change and fix the size of graphics window? | Rob | FLUENT | 1 | February 7, 2003 10:15 |
Problem: graphics display in prostar main window | Jiaying Xu | Siemens | 8 | February 14, 2002 08:08 |
