[OpenFOAM] velocity field for alpha 0 to 0.5 only |
June 11, 2011, 20:14 |
Joel
If I have a free surface model, how could I make a velocity field that is only for the fluid and not for air? I see that I can create a contour and contour by an alpha value of 0.5 which will give me the interface of the fluid and air, but could I make a velocity profile for alpha = 0 to 0.5? |
June 22, 2011, 05:41 |
Hi Xhoven
I don't know whether this is what you want, but what you could do, is to create an Isovolume of alpha from 0 to 0.5 and cut this via a slice. the new slice you can color with the velocity. Cheers, DITO |
June 22, 2011, 06:33 |
Anton Kidess
Rep Power: 29 |
I'm assuming you want to do this in paraview? Use the threshold filter with alpha 0.5, and then the glyph filter on the resulting data set.
[blockMesh] Face reduced to less than 3 points (simple cubic blocks) | mikeR | OpenFOAM Meshing & Mesh Conversion | 7 | July 20, 2023 19:27 |
potential flows, helmholtz decomposition and other stuffs | pigna | Main CFD Forum | 1 | October 26, 2017 08:34 |
Unsteady field advected by steady velocity field | t.oliveira | OpenFOAM Running, Solving & CFD | 2 | December 28, 2015 13:42 |
[blockMesh] meshing a cylinder | Nico A. | OpenFOAM Meshing & Mesh Conversion | 0 | April 7, 2011 11:09 |
[blockMesh] Blockmesh error - 2D scramjet | ishaninair | OpenFOAM Meshing & Mesh Conversion | 7 | March 18, 2011 00:14 |
