Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Region support for utilities
Old   July 27, 2012, 09:07
Default Region support for utilities
Per Nilsson
borrbyper is on a distinguished road
I would like to run post-processing utilities (e.g. Q) on multi-region cases.
(My present case is similar to the chtMultiRegionFoam tutorial and run in parallel, but reconstruced for the PP.)
These utilities do not seem to have region functionality in 2.0.x though.
Do you have a hint on how to
either add this functionality (which seems not quite straightforward to a C++ newbie as these utilities now use function prototyping)
or work around it without having to create a dummy case without region folders.
Regards,
Per
borrbyper is offline   Reply With Quote
multi-region utility
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 19:13
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
