Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
how to make a graph using sampleDict
Old   July 25, 2012, 12:03
Default how to make a graph using sampleDict
Jian Zhong
zxj160 is on a distinguished road
I am new to openfoam and I am trying to use sample utility. I have run the sampleDict. But now I do not know how to make a graph base on the sets files generated.
zxj160 is offline   Reply With Quote
Old   July 25, 2012, 18:36
Assistant Moderator
Bernhard Gschaider
Depends on the format you specified to write them out. But I guess the fastest choice (once you get to know it) is gnuplot. Otherwise a lot of programs (especially those specialized in plotting) can read data from files where the numbers are separated by spaces (excel, OpenOffice, ...)
Old   July 26, 2012, 08:00
Jian Zhong
If my format is set as : setFormat raw;, then how can I read the data and plot them?
Old   July 26, 2012, 08:40
Bernhard
Bernhard is on a distinguished road
gnuplot -persist <<< "plot 'filename.raw'"
Is the easiest method from scratch.
This is something you should fit to your needs with a software of choice. It is a matter of taste and experience. Some people prefer gnuplot, some prefer grace, some prefer Excel, some prefer matlab to make graphs. I would advise gnuplot however. Start with a tutorial, and then google for the things when you need them. This most often works.
Bernhard is offline   Reply With Quote
Old   July 26, 2012, 08:48
Jian Zhong
Originally Posted by Bernhard View Post
Thanks for your advice. Then I will try the gnuplot tutorials first.
Old   July 26, 2012, 09:31
Default suface
Sören
despaired student is on a distinguished road
would you also recommend gnuplot to visualise planes out of raw or vtk formats. To make the files I used sampleDict - surfaces.
Kind regards
despaired student is offline   Reply With Quote
Old   July 26, 2012, 10:36
Bernhard
For vtk-surface I would use Paraview to visualize. Alternatively you can use a tool as Tecplot, but that one is not freely available.
Old   July 26, 2012, 12:07
Jian Zhong
I want to sample data from a surface and then average those with the same y position. Later I want to plot a line with those averaged values. Is it possible to do that?
Old   July 30, 2012, 10:35
hewei is on a distinguished road
hello Berhard,
I used sampledict to get the data at one point, then in the directory of "sets",there are thousands folders in sets.and the data format is gnuplot.
I use the command gnuplot -persist <<< "plot 'somePoints_U.gplt'" in the case home directory, but the result is
line 0: warning: Skipping unreadable file "somePoints_U.gplt"
line 0: No data in plot
but after I delete the head words in the .gplt file,it can be plot in the subdirectory of folder,gnuplot works,but this is not effective.
What's my problem?
Thank you~
hewei is offline   Reply With Quote
Old   July 30, 2012, 10:40
Bernhard
Well, my example was for a datafile with two column from a probe point or something similar. You mayt want to show the function object or sampling you are actually using, as well as the head of the outputfile.
Old   July 30, 2012, 15:52
Sören
Hi hewei,
I don't know what you need to "sample" data at one point for. Maybe you can also use the probeUtility to do this job (if it's data at one point over the time) and visualise the data with python - maybe there exists already a short script for python to do this.
Old   August 1, 2012, 05:04
I wanna calculate the frequency of vibration. and I compared the results between ProbeLocation and sample, they are not the same! My friend told me that probeUtility is sensitive on the grid knot location.
Originally Posted by despaired student View Post
Hi hewei,
Old   August 3, 2012, 04:47
Sören
I don't know in whch way the probe-utility is sensitive on the grid... I hear this the first time but I'm new to OpenFoam so that doesn't mean a thing...
Maybe a more experienced user could comment this...
Old   August 3, 2012, 06:47
I just made this decision after comparing the results gotten by sampledic and probelocation. But I really know what's the reason why. as you said, waiting for experienced users.
graph transient post data at sensor point Micha Siemens 6 March 20, 2013 04:17
use of Gturbo to make turbine blade usman FLUENT 0 December 31, 2007 05:47
How to plot different model's graph on a graph? echo Siemens 1 April 28, 2006 03:54
Mass flow rate graph Lior FLUENT 0 March 7, 2004 10:02
[Q]How to make MPEGs with CFD datas??? Bum-Seok Hyun Main CFD Forum 4 February 16, 2000 18:59
