Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Problem with writing fields with foamToVTK
Like Tree1Likes
  • 1 Post By Kirils
Old   August 5, 2013, 05:26
Default Problem with writing fields with foamToVTK
Kirils Surovovs
Kirils is on a distinguished road
Hello everyone!
I'm very new at OpenFOAM and I can't solve the following problem. Please help me or send a link to solution (I tried but couldn't find it).
I had run 2D axially symmetrical calculations based on chtMultiRegionFoam tutorial (see the case attached). Mesh is very simple, hand-written in blockMeshDict. Then I created two regions using setSet. When I launch chtMultiRegionFoam, it seems that calculation are OK with no errors. Then I write "foamToVTK -time 500" and it still seems to be OK. I get the following on screen:
Create time
Create mesh for time = 500
Time: 500
    Internal  : "/home/kirill/openfoam/KS_test/8_wedges_from_BlockMesh_multiRegion/VTK/8_wedges_from_BlockMesh_multiRegion_5000.vtk"
    Original cells:200 points:451   Additional cells:0  additional points:0
    Patch     : "/home/kirill/openfoam/KS_test/8_wedges_from_BlockMesh_multiRegion/VTK/top_faces/top_faces_5000.vtk"
    Patch     : "/home/kirill/openfoam/KS_test/8_wedges_from_BlockMesh_multiRegion/VTK/bottom_faces/bottom_faces_5000.vtk"
    Patch     : "/home/kirill/openfoam/KS_test/8_wedges_from_BlockMesh_multiRegion/VTK/side_faces/side_faces_5000.vtk"
    Patch     : "/home/kirill/openfoam/KS_test/8_wedges_from_BlockMesh_multiRegion/VTK/axial_faces/axial_faces_5000.vtk"
    Patch     : "/home/kirill/openfoam/KS_test/8_wedges_from_BlockMesh_multiRegion/VTK/wedge_faces/wedge_faces_5000.vtk"
End
But the problem is: when I open .vtk file with ParaView, I cannot see temperature field. I see only what is shown in attached screenshot - cellID and cellNormals. Still, in the folder "500" there is normal "T" file with good values.
Can anyone please help me, how to display temperature field in ParaView?
deep shekhawat likes this.
Kirils is offline   Reply With Quote
Old   September 10, 2013, 08:22
Default Solution
Kirils Surovovs
The problem is solved. ParaView was working wrong because of bad mesh - not every hexagon had exactly six boundary faces.
chtmultiregionfoam, foamtovtk, paraview
How to Mix AIR and WATER Elvis1991 FLUENT 12 December 1, 2016 12:28
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
Problem while writing pressure file "buoyantPressure" ubaid OpenFOAM 0 October 2, 2010 14:07
foamToVTK & foamDataToFluent problem! germinal OpenFOAM Bugs 1 August 17, 2010 05:02
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
