June 15, 2009, 15:33 |
Plotting of an oscillating droplet
Rep Power: 16 |
Hi Foamers,
i've initialised an elliptical droplet under zero gravitation and i want to get a plot of the oscillation of one axis. Is this possible with OpenFoam? The additional problem is that the droplet starts moving because of parasitic currents, therefore the position of the droplet isn't constant. Edit: I already solved the problem. Thanks. Last edited by openTom; June 16, 2009 at 13:01. |
January 7, 2013, 13:12 |
Hossein Yahyazadeh
Rep Power: 13 |
Is it possible for you to declare for me how you have made an elliptic drop? It is very important for me to validate my results. Thanks in advance |
January 7, 2013, 13:28 |
Rep Power: 16 |
i'm no longer working with OpenFoam, but perhaps this extract from my thesis helps you in this case: "The cylindrical shape can easily be initialized by the setFields utility of OpenFOAM. A further utility named funkySetFields is used for the initialization of the elliptical droplet. This tool offers the possibility to initialize complex fluid forms. The equation of an ellipsoid is needed for this purpose: x2/a2 + y2/b2 <= 1 This equation can easily be translated into the code of the funkySetFields utility. The x and y coordinates are subtracted by 0.05 units for placing the shape in the domain center. The semi major axis a of the ellipsoid constitutes 0.015m and the semi minor axis b constitutes 0.01m in this test-case." Best regards Tom |
January 7, 2013, 13:41 |
Hossein Yahyazadeh
Rep Power: 13 |
dear Tom,
Thanks for your reply. I don't know how to define the elliptic drop in setfields, a circular drop is defined as "sphereToCell" as you know. But what shod be replaced for an elliptic one? |
January 7, 2013, 13:43 |
Hossein Yahyazadeh
Rep Power: 13 |
further, should I install funkySetFields on openFoam?
January 7, 2013, 13:48 |
Rep Power: 16 |
As far as i can remember, i used the tool funkySetFields for the elliptical shape. You should install it. Unfortunately, i haven't the data on my current notebook.
January 7, 2013, 13:57 |
Hossein Yahyazadeh
Rep Power: 13 |
Thanks Tom, I will go through it.
droplet falling - VOF | bohis | FLUENT | 1 | July 10, 2013 04:28 |
Importance of droplet size | Itchie | CFX | 2 | December 13, 2007 02:01 |
Why is droplet track file overwritten ? | mic | Siemens | 6 | July 12, 2007 10:46 |
Plotting Droplet velocity -DPM | joshkemp | FLUENT | 1 | April 12, 2007 20:09 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
