How to get the cells coordinate
Like Tree9Likes
  • 7 Post By fumiya
  • 2 Post By opedrofunk
Old   January 17, 2013, 21:33
Question How to get the cells coordinate
Wang Han
whyingwang is on a distinguished road
Hi,foamers
Recently I get some troubles.The reslut store in the time file,e.g. 100,200.
The value store the cell's value.But in the polyMesh folder,the points file store the point's coordinate.I don't find the cells file,only the cellZone file.
I want to know, How can I get every cells coordinate?I can only see the point's coordinate, not the cell's.
Thanks
whyingwang is offline   Reply With Quote
Old   January 18, 2013, 10:32
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
The cells file is not necessary to run the OpenFOAM applications.
I don't understand what exactly you mean by the cell's coordinate,
but you can access the coordinates of cell centers using the
mesh.C():
forAll(U, cellI)
    Info<< mesh.C()[cellI] << endl; //cell center coordinate of cellI
You can also use the utility "writeCellCentres" to output to the file.
Hope that helps,
Fumiya
fumiya is offline   Reply With Quote
Old   February 3, 2015, 23:53
Default Here's a utility I wrote to write the cell centers to a file at each specified time.
Peter
opedrofunk is on a distinguished road
Download, instructions, usage, and examples are here:
https://bitbucket.org/peterjvonk/cellcenters
You can use the utility in the standard way, i.e.:
$ cellCenters -latestTime
Or in parallel:
$ mpirun -np <num-processors> cellCenters -parallel -latestTime
This is a bit different than the writeCellCentres utility that comes with OpenFOAM, as it writes the vector to a single file (rather than to three separate files, one for x, y, and z). I found it a bit cumbersome to work with three files, so I wrote this. Hope it helps.
Regards,
Peter
nishant.kumar and Utkan like this.
opedrofunk is offline   Reply With Quote
Old   March 21, 2015, 15:05
Retired Super Moderator
Bruno Santos
Greetings to all!
@Peter: I've created a basic wiki page to help getting your cellCenters utility known to the community that uses OpenFOAM technology: http://openfoamwiki.net/index.php/Contrib/cellCenters
May you or anyone else feel free to update that wiki page!
Best regards,
Bruno
Old   October 25, 2017, 03:51
Ayush Agrawal
ayushmorx is on a distinguished road
I am trying to get cellCenters working for the past couple of days, but unfortunately I am having problems using it. I have attached the output here. Would be glad for any help!
| \\ / O peration | Version: 4.1 |
| \\/ M anipulation | |
Build : 4.1
Exec : cellCenters
Date : Oct 25 2017
Time : 03:44:04
Host : "Ayush-Work"
PID : 19641
Case : /media/ayushmorx/HD2/lownu_mine
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 5
Time = 5
--> FOAM FATAL IO ERROR:
error in IOstream "/media/ayushmorx/HD2/lownu_mine/5/cellCenters" for operation Ostream& operator<<(Ostream&, const char)
file: /media/ayushmorx/HD2/lownu_mine/5/cellCenters at line 18.
From function virtual bool Foam::IOstream::check(const char*) const
in file db/IOstreams/IOstreams/IOstream.C at line 96.
FOAM exiting
ayushmorx is offline   Reply With Quote
Old   March 21, 2022, 02:25
ZhuangLi
zhuangli is on a distinguished road
Or in parallel:
Regards,
Peter
Sorry to bother.
I want to make sure that after using the cellcnter tool ,the order of cell center coordinate in OpenFOAM file is as same as the cellZones ' s order, what my think is right or not?
Thanks in advance.
_________________
Best regards
Zhuangli
zhuangli is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
