Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
combine sampled surfaces
Old   October 1, 2013, 10:50
Default combine sampled surfaces
Eloïse
Eloise is on a distinguished road
I've used the sample tool to extract the U and k field from my simulation in a surface vtk file. For post processing, I'd like to combine those two fields into a single surface vtk file (in order to compute the turbulence intensity).
Anyone has an idea how generate a single surface vtk file which contain both the U and k fields?
Regards,
Eloïse
Eloise is offline   Reply With Quote
Old   October 3, 2013, 10:44
Eloïse
Hi again,
The reason why U and K are not in the same file is because one is a vector while the other is a scalar.
I found a way to calculate Ux and u' fields (which are both scalar) using the commands
foamCalc components U
uprime
So now in my sampleDict, I extract the fields Ux and uprime on a vtk surface. As they are both scalar, they should print into the same file, but they keep coming as two separate files Ux_surf.vtk and uprime_surf.vtk . Any idea why they don't come in a single file Ux_uprime_surf.vtk ?
Otherwise, I'm trying as well to define a turbulenceIntensity command, starting from the uprime.C utility file. However, I have error due to the division by 0 in some points of the field (as TI=uprime/Ux). Anyone knows how to not write fields in the cells where a division by zero occurs?
Thanks,
Eloïse
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
how to get forces on Iso-Clip Surfaces and How to get forces in cylindrical coordinat CFD XUE FLUENT 3 March 18, 2015 03:28
[Commercial meshers] How to get rid of internal walls (surfaces)? bmikuz OpenFOAM Meshing & Mesh Conversion 17 December 5, 2013 15:24
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 s.mishra ANSYS 0 March 31, 2012 04:12
Faceted surfaces in ICEM Chriss Main CFD Forum 1 May 6, 2008 15:18
