Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Time averaging of new variable using fieldAverage
Like Tree2Likes
  • 1 Post By agustinvo
Old   February 5, 2017, 15:59
Default Time averaging of new variable using fieldAverage
Mirage
Mirage is on a distinguished road
Dear Foamers,
I m writing the heat flux as output only for the last time step and I would like to average this latter parameter over the time using the fieldAverage function.
It works fine for standard variable like p or U. I am getting UMean and pMean as an output and the values are physical after averaging over a long time.
However I am not able to average any new variable, that I m calculating in my customized solver.
Here is the function, that I writing in controlDict:
 fieldAverage1
        type            fieldAverage;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled         true;
        outputControl   outputTime;
        fields
            TurbFlux
                mean        on;
                prime2Mean  on;
                base        time;
Is it possible to average non-standard variable?
I am wondering, what i am doing wrong.
I appreciate any help !
Cheers !
Mirage is offline   Reply With Quote
Old   February 6, 2017, 22:37
Mirage
Should I define the new variable in the OpenFoam libraries ?
Any help or answer is appreciated
Old   February 8, 2017, 05:35
Agustín Villa
agustinvo is on a distinguished road
Hello
I passed through this two weeks ago. First of all, if you can include that variable in your code, that's is the easiest, but if you define Turbflux for example as a Swak4Foam field in yout controlDict, please take a look to this:
https://www.cfd-online.com/Forums/openfoam-programming-development/142749-using-fieldaverage-together-swak4foam-expressionfield.html#post622399
BTW, are you trying to get the turbulent heat flux from your simulations?
Mirage likes this.
agustinvo is offline   Reply With Quote
Old   February 11, 2017, 17:54
Mirage
Thanks !!
I managed to calculate the turb flux using the expressionfield of swak4foam tool.
However I am really interested on calculating the average variable in the code.
I could define the flux as variable in the solver. Nevertheless I was not able to average it.
fieldaverage function is not allowing the averaging of non-standard OF variables.
Do you know, if I could define the time averaging on the solver?
Old   February 12, 2017, 06:37
Agustín Villa
you may take a look into the code of fieldAverage. Me, I've never tried to do so.
What I do is, in my solver, define some auxiliar variables, that I use later to create my turbulent heat flux.
The THF is defined as <u'T'>, but it can be decomposed, follogind the ensemble averaging, as <u'T'>=<UT> - <U> <T>, so you need to create a variable UT, you get the mean of UT, U and T, and then with expressionField you get u'T'.
This is what I do, but fi you find any other easier way to get it, make us know!
lpz456 likes this.
Old   March 29, 2017, 22:43
Harshal Akolekar
hakolekar is on a distinguished road
Is it possible to find the field average (over a certain time interval) of volScalarFields in the defined in the member functions of OpenFoam - without using the swak4foam?
For example - the production term in the k equation.
I have already defined this as an IO object and have a data set for this term in my time directories, but it does not produce field averages and instead states:
Field Pkt not found in database for averaging
If anyone has any ideas, it would be appreciated.
Regards,
Harshal
hakolekar is offline   Reply With Quote
Old   November 9, 2019, 21:30
kkpal is on a distinguished road
Hi Harshal,
Have you found a solution to this?
Originally Posted by hakolekar View Post
Regards,
Harshal
kkpal is offline   Reply With Quote
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
