Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
foamToVTK problems
Old   March 8, 2013, 20:21
Default foamToVTK problems
Gabriel de PInho RImoli
Grimoli is on a distinguished road
Guys,how do I use the command foamtoVTK??When I'm using it at the chtMultiRegionSimpleFoam tutorial,the temperature option doesnt work,and when i put it to work,it doesnt work at all.Do I have to use the command as : foamToVTK topAir as example??PLease I need some help
Grimoli is offline   Reply With Quote
Old   March 9, 2013, 12:55
Rexxar
czhao86 is on a distinguished road
If you want to show results about particles,
after the XXXFoam command,
just run 'foamToVTK'
then a folder named 'VTK' will be created
you can use paraview to load geometry VTK and lagrangian VTK, and check the results.
Best,
Rexxar
czhao86 is offline   Reply With Quote
Old   March 9, 2013, 14:17
i tried it,but it wasnt working at all,it seems i have to change something at some dict or whatever
Old   March 10, 2013, 17:07
Davide D.
dav.dap83 is on a distinguished road
Can you write the error message?
dav.dap83 is offline   Reply With Quote
Old   March 10, 2013, 17:18
Retired Super Moderator
Bruno Santos
Greetings to all!
@Grimoli: Have you tried running the following command?
foamToVTK -help
If you want to export to VTK the "topAir" region, you can run:
foamToVTK -region topAir
Best regards,
Bruno
Old   November 15, 2013, 06:53
Samuele Z
samiam1000 is on a distinguished road
Dear Bruno,
I did as you suggested but I get this error:
lab@lab-laptop:/media/My world/PCMPacks/steadyNoFlux$ foamToVTK -allPatches -ascii -region fluid
|  \\    /   O peration     | Version:  2.2.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.1-57f3c3617a2d
Exec   : foamToVTK -allPatches -ascii -region fluid
Date   : Nov 15 2013
Time   : 11:46:21
Host   : "lab-laptop"
PID    : 4907
fileName::stripInvalid() called for invalid fileName /media/Myworld/PCMPacks/steadyNoFlux
    For debug level (= 2) > 1 this is considered fatal
Aborted (core dumped)
samiam1000 is offline   Reply With Quote
Old   November 15, 2013, 16:46
Bruno Santos
Hi Samuele,
OpenFOAM hates spaces in folder names. In this case, the folder name "My world" is invalid for OpenFOAM to use.
Best regards,
Bruno
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 04:45
[OpenFOAM] foamToVTK and paraFoam show different results akidess ParaView 2 October 29, 2010 06:36
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 12:00
