Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] How to Plot Eddies in Paraview :)
Like Tree15Likes
  • 2 Post By zhernadi
  • 1 Post By Alhasan
  • 2 Post By immortality
  • 1 Post By zhernadi
  • 7 Post By wyldckat
  • 2 Post By Alhasan
Old   June 10, 2013, 17:00
Default How to Plot Eddies in Paraview :)
Alhasan's Avatar
Hasan K.J.
Alhasan is on a distinguished road
Hey All,
i am Trying to get eddies for LES case on my paraview in openFOAM
- i switched the contours on !! no help and i dunno where to go what to do get the eddies like the ones i have attached in the image
Please help
Thanks for your time
Hasan K.J
Alhasan is offline   Reply With Quote
Old   June 11, 2013, 08:12
Default vortex detection criteria
Zoltan Hernadi
zhernadi is on a distinguished road
Dear Hasan,
It depends on the vortex detection criteria. You may try using Q utility to generate second invariant of the velocity gradient tensor and visualize a contour of this field. Other option is using Lambda2 utility. But there are other vortex detection criteria as well. I hope this helps.
Zoltan
Alhasan and rajibroy like this.
zhernadi is offline   Reply With Quote
Old   June 12, 2013, 21:33
Default Where is Q utility and Lambda 2 utility
Alhasan's Avatar
Hasan K.J.
Hey Zoltan,
I am not able to find these two utilities the Q utility and Lambda 2 utility ?
- please can u tell where the option is in paraview ?
- i searched i am not able to locate it
Thanks
Regards,
Hasan K.J
nanavati likes this.
Old   June 13, 2013, 01:19
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi
Execute the commands in terminal.
Alhasan and fportela like this.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 13, 2013, 02:25
Zoltan Hernadi
In addition to Ehsan's help, you might be interested in this list of OpenFOAM utilities:
http://openfoam.org/docs/user/standard-utilities.php
Alhasan likes this.
Old   June 13, 2013, 16:41
Ehsan
Hi hasan
could you see the vortices?could you attach them?
I used lambda2 and Q without sucess.not any vortices are displayed!
Old   June 13, 2013, 16:49
Alhasan's Avatar
Hasan K.J.
No... i havent tried it yet ? but does it actually make a difference if its LES or RAS case...?
Old   June 13, 2013, 17:02
Ehsan
i don't think it has a lot of effect on vortices.
what your opinion dear Zoltan?how could I set a contour for labda or Q?is the wide range normal in your opinion?
Old   June 13, 2013, 20:04
Exclamation Lambda2 error
Alhasan's Avatar
Hasan K.J.
Hey guys,
My life is never simple and i will never get used to it
- i typed Q and it worked fine with my case
- then i typed Lambda2 and i get this error does any body know what this error means and whats causing it
- and Ehsan if you manage to get the eddies please let me know
Regards,
Hasan K.J.
and it works only for last time with some warning
Create mesh for time = 10000
Time = 10000
Reading U
--> FOAM Warning :
From function eigenValues(const tensor&)
in file primitives/Tensor/tensor/tensor.C at line 174
complex eigenvalues detected for tensor: (1902.57 7.65293e-07 -0.000402738 7.65293e-07 1902.57 3.34481e-05 -0.000402738 3.34481e-05 4.34386e-10)
--> FOAM Warning :
complex eigenvalues detected for tensor: (1902.57 7.65152e-07 -0.000250995 7.65152e-07 1902.57 2.85284e-05 -0.000250995 2.85284e-05 1.62937e-09)
--> FOAM Warning :
complex eigenvalues detected for tensor: (1902.57 7.65293e-07 0 7.65293e-07 1902.57 0 0 0 2.587e-09)
Writing -Lambda2
End
Create time
Create mesh for time = 0
Time = 0
Reading U
#0 Foam::error:rintStack(Foam::Ostream&) in "/panfs/storage/local/non-commercial/OpenFOAM/OpenFOAM-SGISLES11-2.1.X_X8664_21JUNE12_REPO/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/panfs/storage/local/non-commercial/OpenFOAM/OpenFOAM-SGISLES11-2.1.X_X8664_21JUNE12_REPO/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#2 in "/lib64/libc.so.6"
#3 acos in "/lib64/libm.so.6"
#4 Foam::eigenValues(Foam::Tensor<double> const&) in "/panfs/storage/local/non-commercial/OpenFOAM/OpenFOAM-SGISLES11-2.1.X_X8664_21JUNE12_REPO/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#5 Foam::eigenValues(Foam::Field<Foam::Vector<double> >&, Foam::UList<Foam::Tensor<double> > const&) in "/panfs/storage/local/non-commercial/OpenFOAM/OpenFOAM-SGISLES11-2.1.X_X8664_21JUNE12_REPO/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
in "/panfs/storage/local/non-commercial/OpenFOAM/OpenFOAM-SGISLES11-2.1.X_X8664_21JUNE12_REPO/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/bin/Lambda2"
#10 __libc_start_main in "/lib64/libc.so.6"
#11
at /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/x86_64/elf/start.S:116
Floating point exception
Old   June 13, 2013, 20:42
Unhappy No Luck
Alhasan's Avatar
Hasan K.J.
Hey guys,
the maximum i can get to with my only working Q utility is this much
i tried contours with the Q selected nothing works ?
- if anybody manages to get it or know how to get it please help us
thanks
Regards,
Hasan K.J
Old   June 14, 2013, 02:42
Ehsan
how should set contour settings for a good figure?
its a test case.
whats the stages to see vortices contours?
thanks.
Old   June 16, 2013, 12:22
Retired Super Moderator
Bruno Santos
Greetings to all!
OK, using Ehsan's test case, here's what's going on: you are being blind-sighted by the maximum values. You need to change the scales down to lower values, such as [-200000, 200000], as shown in the 1st attached image.
If you don't know how to change the scale, read this post: http://www.cfd-online.com/Forums/ope...tml#post429974 - post #2.
As for contours, from the menu, choose "Filters -> Alphabetical -> Contour". Then configure as shown in the second image.
Best regards,
Bruno
File Type: jpg Screenshot from 2013-06-16 17:20:15.jpg (45.5 KB, 534 views)
Old   December 2, 2013, 19:37
youjingxuanlin is on a distinguished road
hi, Alhasan
Have you solved the error with Lambda2? if so, please tell me how to solve it? thanks
youjingxuanlin is offline   Reply With Quote
Old   December 3, 2013, 09:16
Alhasan's Avatar
Hasan K.J.
Originally Posted by youjingxuanlin View Post
hi, Alhasan
Hi Youjing,
The problem i had was sorted when i put the right value for the Q criterion that i was trying to get on paraView
- First you use the Command and get the Q or Lambda2 from openFOAM
- then you paraView and select the contour botton and apply
- then select the Lambda2 within the Contour dialogue box
- then choose the right range or value, - if you dunno the right range play with the values till you get what you are looking for
All the Best,
Hasan K.J
wyldckat and hulli like this.
Old   December 5, 2013, 19:47
Originally Posted by Alhasan View Post
Hi Youjing,
All the Best,
Hasan K.J
Thanks for your fast reply, i think i can solve it now!
[OpenFOAM] How to plot flow rate over time with Paraview sekunda ParaView 17 July 23, 2020 13:14
[OpenFOAM] Paraview: Plot over line only displays line for untranslated data Illmatic ParaView 1 January 13, 2020 11:42
Different results using sample utility vs Paraview 'Plot over line' tool agarwa58 OpenFOAM Post-Processing 5 March 20, 2016 08:57
[General] Paraview: plot over a certain value and add axis nwpukaka ParaView 1 May 16, 2014 16:01
[OpenFOAM] Plot of different variables using Paraview subhkirti ParaView 0 December 23, 2010 05:22
