Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
calculating integrated quantities: surface average
Old   December 10, 2013, 00:55
Default calculating integrated quantities: surface average
Sergey
skuznet is on a distinguished road
Hello!
Is any simple way in OpenFoam of in Paraview to calculate integrated quantities, such as surface average of temperature?
I'm trying to simulate conjugate heat transfer in a fin and would like to calculate heat transfer coefficient.
Thank you!
skuznet is offline   Reply With Quote
Old   January 15, 2014, 16:14
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Howdy!
You should be able to use the command line patchAverage utility like this:
> patchAverage T myPatchName
BAM!
I hope that does what you wanted!
Cheers!
Kyle
kmooney is offline   Reply With Quote
[ICEM] Surface mesh not sticking to surface holtwong ANSYS Meshing & Geometry 2 April 20, 2023 08:28
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
Calculating average wall shear? Joe CFX 3 March 17, 2007 09:42
PostProcessing- Calculating average value at secti mrs Siemens 1 October 10, 2006 07:59
Calculating the average y+ value Sebastiaan Bottenheim FLUENT 1 May 11, 2004 09:25
