Time history of wall Shear Stress.
Hi
I need a little help. I wanted to observe how the wall Shear Stress changes over time for my case. To achieve that, I execute wallShearStress utility, which creates the wallShearStress field in all the (written) time-step folders (startTime startTime + writeInterval startTime +2*writeInterval ... and so on till endTime). Does anybody know how I can extract the 'wall' patch value of wallShearStress from each of these folders and plot them as a function of iterations/time steps? Any comments are welcome! |
I guess there can be another solution but usually I do the following: 1. Sample values of a field (in your case wallShearStress) with sample utility; it will create folders postProcessing/surfaces/* with sampled data in them 2. Use python to iterate over created folders to read values in array [time, value] 3. Use matplotlib to plot values Surely you can substitute python and matplotlib with preferred software. But I is your wall shear stress constant over the wall patch? |
Thanks Alexey
I did not think of using Python to extract the values from the folders, so that is a start. I have just two cells in the x direction along the wall patch. The wallShearStress does not vary so much between them. |
Actually I've recalled more convenient way of doing what you want. There's an utility probeLocations. You create probesDict in system folder of your case (you can find example in $FOAM_APP/utilities/postProcessing/sampling/probeLocations), run the utility and it will create files in postProcessing/probes with time evolution of the field at a given location. |
