September 18, 2017, 17:18 |
wallGradU
Alejandro
Rep Power: 12 |
In the new openfoam 5 wallGradU has been superseded by the postProcess utility:
postProcess -func 'grad(U)' but is technically the same? wallGradU was not calculating the grad(U) normal to the surface? wallGradU.boundaryField()[patchi] = -U.boundaryField()[patchi].snGrad(); How can i use the new postProcess -func 'grad(U)' to get information normal to the surface? |
September 19, 2017, 16:47 |
Alejandro
Rep Power: 12 |
someone can explain how to use postProcess -func 'grad(U)' and get results at the wall normal surface?
I am just obtaining a tensor instead a vector for the wall. I would like to recover results as wallGradU. Thanks |
September 18, 2018, 13:26 |
sibo
Rep Power: 9 |
Hi Colli,
I'm wondering did you find the solution? I am facing the same problem! Thanks a lot! |
September 18, 2018, 13:40 |
Alejandro
Rep Power: 12 |
They removed the functionality, Maybe the wallShearStress post-process functionalitty will be useful for you.
I was using wallGradU in order to modify it for mass flux at the wall. Finally, I modified wallHeatFlux in order to obtain what i wanted. Regards |
September 18, 2018, 13:41 |
sibo
Rep Power: 9 |
Thanks for your help!
Display Modes | |
wallGradU components | amin66 | OpenFOAM Post-Processing | 9 | March 25, 2016 21:09 |
wallGradU at runtime | kkpal | OpenFOAM Post-Processing | 6 | June 12, 2015 20:56 |
getting (0 0 0) wallGradU value when i m probing wallGradU at some points | suryawanshi_nitin | OpenFOAM | 1 | December 9, 2013 12:36 |
wallShearStress VS wallGradU | bigrock | OpenFOAM Post-Processing | 0 | July 2, 2013 06:54 |
write wallGradU to one file | sven | OpenFOAM | 1 | March 19, 2011 19:58 |
