Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
OpenFoam pitch moment problem
Like Tree1Likes
  • 1 Post By tomf
Old   March 19, 2014, 14:00
Default OpenFoam pitch moment problem
Albert
Mecsocse is on a distinguished road
Hi Foamers,
First of all, it is a pleasure being part of this community.
My name is Albert and I am part of the aerodyamic team in a formula student car. So far, we were simulating with Ansys k-omega and now we are starting with OpenFoam.
We are using the same model of turbulence, and the cd and cl are very similars but the PitchMoment is very different . Anybody has any idea of what is hapenning? The origin in both cases is located in the same place.
Thank you very much,
Albert
Mecsocse is offline   Reply With Quote
Old   March 20, 2014, 01:58
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Albert,
I think it could help you if you divide your car into multiple parts and compare forces on each part to look for any differences. For instance if you have a front wing assembly check wat both softwares are giving for lift and drag values on the front wings. Same for tires, ground plane, rear wing etc.
Or you can have a look at the pressure distribution on the entire car and see if you can spot any differences.
Finally the best would be to have an experiment to compare both simulations with, maybe from an older car? I think this is all about validating your simulations.
Looking at forces and moments is an indication, but it may well be that you simulations just are off in two different areas and happen to cancel out errors in forces, but not in moments. So if you can compare with pressure distributions or flow visualisations that can give you an idea what is wrong and what is right.
Regards,
Tom
ngj likes this.
tomf is offline   Reply With Quote
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Problem in fvMesh.C when using topological changes. OpenFoam 2-2-x Horacio Aguerre OpenFOAM Programming & Development 0 August 14, 2013 11:57
To solve combustion problem in openFoam yash.aesi OpenFOAM 0 July 10, 2013 07:35
compiler problem with OpenFOAM installation belkadi OpenFOAM Installation 4 May 22, 2013 10:26
[OpenFOAM] Color display problem to view OpenFOAM results. Sargam05 ParaView 16 May 11, 2013 00:10
