foamDataToFluent
hello
I need to export OpenFoam 220 data to fluent for plotting axial velocity contours which I can't plot them with Paraview and I followed this instruction http://www.cfd-online.com/OpenFOAM_D...es/1/1212.html but It didn't solve my problem and I got this error ::confused: --> FOAM FATAL IO ERROR: cannot open file file: /home/ali/OpenFOAM/ali-2.2.0/run/tutorials/incompressible/icoFoam/u/system/foamDataToFluentDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 87. I would be so appreciate if someone give me detailed instruction . thanks |
In /OpenFOAM-2.2.2/applications/utilities/postProcessing/dataConversion/foamDataToFluent you can find an exampe (which you have to copy into your case's system directory:
/*--------------------------------*- C++ -*----------------------------------*\ Code:
p 1; |
I got it .thanks.
It was really helpful but (.cas) file was not made and I just have (.dat) files for each time step so fluent can't open it and give me an error that (.cas) file in necessary. |
If I remember correctly, the .cas file contains the mesh. You can create it with foamMeshToFluent.
thanks it works
thanks for your attention and answers. |
Hi
I use foamDataToFluent and I get the uotput results in openfoam with Suffix .dat then I bring it to CFD post but encounter to this problem : cannot get mesh information.look likes mesh file is missing I don't know how add mesh file to CFD post. It's enough to put polymesh in folder that .dat existence thanks Masoud |
