integration in postprocessing
1 Attachment(s)
I need to integrate the following equation for all time steps. http://www.cfd-online.com/Forums/att...1&d=1396238895 U(y) is instantaneous velocity from simulation. y is in vertical direction and C is a constant. I need to calculate it for every meshgrid in x direction (streamwise). Anyone can help? Thanks mmmn |
Hi
I'm also facing this problem. I found this http://www.cfd-online.com/Forums/ope...tml#post221235 But I can't compile the code, with the error without .dep file. Perhaps the code only works for of-1.6. I'm a little confused about the integration in openfoam. If I want to integrate a variable, is it means that sum(U*dL)/L,U is the variable value on the cell center and L is the direction you want to integrate, dL is the length of the cell in this direction |
