Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Stream Functions in InterFOAM
Old   April 29, 2014, 19:00
Default Stream Functions in InterFOAM
Deepak Kalaikadal
kalaikdr is on a distinguished road
I am working with drops spreading on a surface. My simulation with interFOAM works fine, and I am able to extract the stream function using the streamFunction utility. However, I want my stream functions to be separate for air and water. How do i go about this?
kalaikdr is offline   Reply With Quote
Old   June 5, 2014, 11:06
Niu
Z.Q. Niu is on a distinguished road
Dear Deepak,
Is your model 3-D or 2-D? I have used streamFunction utility in my model, but it didn't work!
Best regards!
Z.Q. Niu
Z.Q. Niu is offline   Reply With Quote
Old   June 5, 2014, 14:18
Deepak Kalaikadal
streamFunction utility does not work for a 3D model. stream functions are defined for 2D flows only!
Old   June 6, 2014, 03:18
Niu
Thank you ! But I want to plot the streamlines at a cutting plane in 3-D channel to observe secondary mean flow, do you have good method?
interfoam, stream functions, streamfunction
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
[Commercial meshers] CCM+ Mesh Conversion Ingenieur OpenFOAM Meshing & Mesh Conversion 17 February 2, 2014 09:34
Boundaryconditions for twophase stream through open "channel" , InterFoam Wedge Antilles OpenFOAM Pre-Processing 0 February 13, 2013 11:47
Streamfunction? cain Main CFD Forum 5 July 19, 2012 10:05
Stream Functions in a 3D problem Shamoon FLUENT 5 August 16, 2009 12:49
