[swak4Foam] Error using patchAverage from swak4Foam |
June 8, 2014, 17:59 |
Luca
Rep Power: 15 |
Dear all,
I want to write the an average field on two patches, namely inlet and outlet of a duct, using the functionObject patchAverage from swak4Foam. The code I entered in controlDict file is the foloowing: Code:
velAreaWeightAvg { type patchAverage; verbose true; fields ( Uz ); patches ( inlet outlet ); factor 1.0; outputControlMode outputTime; outputInterval 1; allowCoupled true; // because the patches are cyclic coupled } Code:
--> FOAM Warning : From function probes::read() in file patch/patchFieldFunctionObject/patchFieldFunctionObject.C at line 100 Unknown field Uz when reading dictionary ".patchAverage" Can only probe registered volScalar, volVector, volSphericalTensor, volSymmTensor and volTensor fields Time = 17000 Operating in no-flow mode; no models will be loaded. All vol, surface and point fields will be loaded. Reading volScalarField Uz Reading volScalarField Uy Reading volScalarField nut Reading volScalarField Ux Reading volScalarField p Reading volScalarField k Reading volScalarField epsilon Reading volVectorField wallShearStress Reading volVectorField U Reading surfaceScalarField phi Thank you in advance, Luca |
June 9, 2014, 05:27 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
June 9, 2014, 06:58 |
Luca
Rep Power: 15 |
Dear Bernhard,
first of all thank you very much for your quick reply. I want to obtain an area weighted average value of some variables and therefore I opted for patchAverage from libSimpleFunctionObjects, as described at the following link: http://openfoamwiki.net/index.php/Co...unctionObjects Now I managed to solve the problem using the following code: Code:
velAvg2 { type patchExpression; variables ( "UzAvg{patch'inlet}=sum(Uz*area())/sum(area());" ); accumulations ( min max ); patches ( inlet ); expression "UzAvg"; verbose true; allowCoupled true; } Could you please make an example of how using the replayTransientBC and/or funkyPythonPostproc to "preload" the necessary fields for my problem? Thank you very much in advance. Luca P.S. I forgot to point out that I installed swak4Foam for OF 2.3.0 |
June 9, 2014, 08:34 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
June 9, 2014, 08:49 |
Luca
Rep Power: 15 |
Dear Bernhard,
I am sorry...you're perfectly right...I am using simpleFoam (actually a modified version that includes a constant pressure drop source term). I use cyclic BC at the inlet and outlet patches of the duct. Here follows my controDict entries: Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // libs ( "libOpenFOAM.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" "libgroovyBC.so" ); application simplePeriodicP; // based entirely on simpleFoam startFrom startTime; startTime 1; stopAt endTime; endTime 20000; deltaT 1; writeControl timeStep; writeInterval 5; purgeWrite 5; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; functions ( patchAverage { type patchAverage; verbose true; fields ( Uz ); patches ( inlet outlet ); factor 1.0; outputControlMode outputTime; outputInterval 1; allowCoupled true; } ); Luca |
June 10, 2014, 14:41 |
#6 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
1. usual fields are created in createFields.H 2. time-loop starts. The functionObjects are initialized. patchAverage doesn't find Uz in memory and removes it from the list (warning) 3. Uz gets created (or read) 4. Usual time-step calculations 5. patchExpression is evaluated. It finds Uz in memory and therefor produces a result
InterDyMFoam+simpleFunctionObject | Elham | OpenFOAM Running, Solving & CFD | 5 | July 10, 2017 11:59 |
source term in near wall cell | rajcfd | OpenFOAM Pre-Processing | 5 | February 1, 2016 10:31 |
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 | kobayashi | OpenFOAM Community Contributions | 2 | January 5, 2014 17:33 |
[swak4Foam] Unknown function patchAverage in swak4Foam (Control Dict) | franzi_ | OpenFOAM Community Contributions | 17 | December 1, 2013 13:53 |
[swak4Foam] fails in parallel with -otherTime? | Phicau | OpenFOAM Community Contributions | 3 | June 26, 2013 13:00 |
