Have a look at the yPlusRAS utility: https://github.com/OpenFOAM/OpenFOAM...ities/yPlusRAS
yPlusRAS computes yPlus values of the boundary patches, right?
yPlus.boundaryField()[patchi] = nutPw.yPlus(); I've done this with help of a utility that calculates yPlus at given positions for inner cells (defined in a probesDict). I am not yet clear about the kinematic viscosity that should be used for that purpose. Due to the physical meaning of yPlus, this dimensionless number is the ratio of turbulent (nominator, ) and laminar (denominator, ) influences. If the first cell center is really close to the wall = ~ 1 or even smaller, because this point is located in the viscous sublayer and friction dominates in this laminar flow regime. = velocity gradient between the wall and the location of the first cell center. In that case the inertial forces and fritcion forces are of the same magnitude. This is apparently the idea of yPlus. y+ is the Re-Number of the viscous sublayer. The graph dimensionless velocity versus yPlus (), shown in papers and books, imply y+ values of inner cells too. How are these yPlus values computed correctly (which and which are used? |
Have a look at http://www.cfd-online.com/Forums/ope...-testcase.html
and this program, which calculates yplus values for all cells in a mesh: https://github.com/chegdan/yPlusUplus I am not sure that you can use them if you use wall functions, but then you probably have to merge these tools with the yPlusRAS utility. |
I've found that code some time ago.
If I understand correctly, this code maps to each inner cell the utau value of the closest boundary face. And for nu it uses the scalarVolumeField nu, which means nuEff (in case of an LES, not nu_laminar). Is that code, according to the physical interpretation of yPlus, correct? |
Hello everyone,
I have modified the code of chegdan for calculating yPlus for all cells. Thanks for his contribution. This is the link to the old code: https://github.com/chegdan/yPlusUplus. This is the link to my code: https://github.com/Ruansh233/RshOpen.../main/yPlusCFD The old version is run on OF-2.1. And my new version can run on OF-v2106 I delete some redundant steps and omit to create too many new objects. My code is running much faster compared to the old version. |
