Newbie: How to get raw format x y z u v w file from OpenFoam |
October 26, 2017, 04:06 |
Ayush Agrawal
Rep Power: 11 |
I am newbie to OpenFoam, and recently ran a case using pimpleFoam. The run was successful, but now I need to postprocess. I am trying to extract a single file with raw data of cell nodes, and the corresponding velocities. I initially tried using writeCellCenters, but it shows 92k+ data points, whereas, my U file only shows 88k+ data points. Clearly either I am missing either U data at nodes or I do not have access to coordinates of the corresponding U velocities. I tried using PyFoamConvertToCSV, but clearly I am doing something wrong and cannot extract the data, not that I understand PyFoam much either. So my question is, how would I best extract the correct node coordinates and correct corresponding velocities in a single file in raw format(x y z u v w). I need the data in my lagrangian codes, as well as possibly plot the data in gnuplot or jplot. |
October 26, 2017, 04:42 |
#2 | |
Ricky
Rep Power: 11 |
Hallo Ayush,
one quick question, have you tried using "sampleDict"? hope this helps! Regards, Ricky Quote:
If it is easy, then something is fishy! |
October 26, 2017, 05:01 |
Ayush Agrawal
Rep Power: 11 |
Hello Ricky,
I tried that, but it seems I can only extract the information for a line or surface. Can I extract information for the whole volume too? |
October 26, 2017, 07:22 |
Ricky
Rep Power: 11 |
Hallo Ayush,
My knowledge of OpenFOAM is rather limited, of course there may be more efficient ways to extract information for the whole volume, but as for now, if you wanna extract the field data at every data point, you can do it in paraView. Step1: Open paraview and on the top right corner of the RenderView click on split vertical or horizontal. Step 2: select the SpreadSheet View, Wollah! you have all the field data for the specified time/iteration Step 3: save the data as CSV and from there you can work it out as you like. If you find any other approach, would be glad to know about it Regards, Ricky
openfoam4.1, postprocessing, raw data |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
