Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
surface sampling - how to compute surface area
Old   September 3, 2014, 11:32
Question surface sampling - how to compute surface area
vut
vut is on a distinguished road
Hello everybody,
I used surface sample in OpenFoam to obtain the velocity fields (U,V,W) over a plane. Thus, I gave a base point and a normal vector to specify A PLANE I wanted to consider.
In the resulting surfaceSampling folder, there are some files:
* faceCenter => X,Y,Z of centers of each elementary face
* U => U,V,W at elementary face
* faces => list of 3 points (3 vertices) of each elementary face
* points => coordinates of these points
(Please bear in mind that I am not sure about the information contained in each file ).
I do the following steps:
* Firstly, I use these files to recognize the coordinates of three vertices of each elementary face.
* Then, these coordinates are implemented to calculate the area of each elementary face.
* The sum of these areas should be equal to the area of THE ABOVE PLANE. However, these two values are different!
May you give me some remarks or advices? They will be really appreciated.
Cheers ,
vut
vut is offline   Reply With Quote
Old   September 8, 2014, 07:27
vut
Does somebody have a suggestion?
Thanks,
vut
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[OpenFOAM] Compute Surface Flow & Integral Victorien ParaView 0 July 8, 2014 05:57
[ICEM] How to build the mesh for 3 injection area within one surface? Ryan_Yang ANSYS Meshing & Geometry 11 April 8, 2012 14:20
Surface integral calculation by undefined area Bloshchitsyn Vladimir CFX 0 November 18, 2007 22:19
Cross section and surface area factor Fabiana CFX 0 January 9, 2006 23:51
