How to calculate heat flow from wall to the surrounding environment in of 2.1.1 |
September 18, 2014, 02:27 |
baran
Rep Power: 11 |
Greeting All,
I am trying to solve a case in chtMultiRegionSimpleFoam for a geometry of cavity is surrounded by some thickness of insulation. My question is how to calculate the heat flow from outside of insulating wall to the environment in openfoam 2.1.1..... Please sugeest how should I do this thing? I have gone through some threads in CFD forum but can't get properly..... Regards, baran |
September 18, 2014, 12:42 |
Alex
Rep Power: 21 |
Hi Baran,
I think what you need is wallHeatFlux utility. This is a post processing tool that computes the heat flux across all boundaries of your geometry. These boundaries need to be specified as wall, if they are previously specified as patch instead I think wallHeatFlux won't compute any flux across them. Hope it helps! Regards, Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! |
September 19, 2014, 00:11 |
#3 | |
baran
Rep Power: 11 |
@ alex ....thanks fro your suggestion....
I tried with Quote:
but for solid region it is not working.... for my case I want to calculate how much heat is flowing from solid wall to environment....which is having mixed boundary condition of h & Tamb..... Regards, baran |
September 19, 2014, 16:09 |
Alex
Rep Power: 21 |
Have you tried the -region flag? If boundaries have been defined as wall it must work.
Regards Alex
September 21, 2014, 23:02 |
#5 | ||
baran
Rep Power: 11 |
Greeting all,
@alex ..I tried with this command but it is searching for file.. Quote:
...it is not reading..... Quote:
please suggest something....... Regards, baran |
September 22, 2014, 00:52 |
#6 | |
baran
Rep Power: 11 |
Hello all,
I just went through solver of the utility...wallHeatFlux...and it is meant for fluid region... Quote:
Regards, baran |
September 22, 2014, 01:58 |
Rep Power: 12 |
I am using chtMultiRegionSimpleFoam solver (OF 2.3 and 2.2) and wallHeatFlux utility works for me. Do you have all needed files?
In fluid region directory I have: - g - RASProperties - thermophysicalProperties - turbulenceProperties In solid region directory I have: - radiationProperties - thermophysicalProperties And look at my fvSchemes settings file for solid region: ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; } laplacianSchemes { default none; laplacian(alpha,h) Gauss linear uncorrected; } interpolationSchemes { default linear; } snGradSchemes { default uncorrected; } fluxRequired { default no; } |
September 22, 2014, 02:13 |
#8 | |
baran
Rep Power: 11 |
I am using OF 2.1...here for solid region file name is .. Quote:
Regards, baran |
September 22, 2014, 13:21 |
#9 |
Alex
Rep Power: 21 |
Are you sure that the file is called solidThermoPhysicalProperties instead of simply thermophysicalProperties??
I have never worked with OF 2.1.1 but i have tried OF 2.2.1 and 2.3.x and the file name in these versions is the second one. Can you post the whole message given out by OF so that it could be easier for the experts (not me) to find the problem? Regards, Alex
September 23, 2014, 04:20 |
#10 | |
baran
Rep Power: 11 |
please suggest how to modify this for solid region.... |
September 23, 2014, 05:45 |
#11 |
Alex
Rep Power: 21 |
The problem is that the file is being searched within the constant folder instead of the constant/solidRegion folder. Besides that you are executing wallHeatFlux instead of WallHeatFlux -region solidRegion.
Regards, Alex
September 23, 2014, 06:57 |
#12 | ||
baran
Rep Power: 11 |
Greeting all,
@Alex....in my case i am unaware oe the command...given by you..so I make a folder of each region separately to check the wall heat flux...... by the command .. Quote:
for further study...I name this solidThermophysicalProperties as thermophysicalProperties.....so i got this kind of comment..... Quote:
baran |
September 23, 2014, 07:26 |
#13 |
Alex
Rep Power: 21 |
Have you defined properly both solid and fluid regions in the "constant/regionProperties" file?
September 23, 2014, 07:31 |
#14 |
baran
Rep Power: 11 |
@ alex...I hope I defined this properly......
but it is not built for solid region....... Regards, baran |
September 23, 2014, 07:40 |
#15 |
Alex
Rep Power: 21 |
Then I don't know what the problem can be... Maybe if you upload your case someone could check it out in order to help you.
Regards and cheer up! Alex
September 25, 2014, 04:25 |
wallHeatFlux utility for solid region in OF 2.1.1
#16 |
baran
Rep Power: 11 |
Greeting all,
In this way i have modified wallHeatFlux utility...for OF 2.1.1 ...now it working properly..... In createField.H Code:
autoPtr<basicSolidThermo> thermo ( basicSolidThermo::New(mesh) ); const volScalarField& T = thermo->T(); tmp<volScalarField> tkappa = thermo->K(); //tmp<volSymmTensorField> tkappa = thermo.directionalkappa(); const volScalarField& kappa = tkappa(); Code:
surfaceScalarField heatFlux ( fvc::interpolate(kappa)*fvc::snGrad(T) ); Code:
EXE_INC = \ -I$(LIB_SRC)/turbulenceModels \ -I$(LIB_SRC)/turbulenceModels/compressible/RAS/RASModel \ -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/basicSolidThermo/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude EXE_LIBS = \ -lcompressibleRASModels \ -lfiniteVolume \ -lgenericPatchFields \ -lspecie \ -lbasicSolidThermo Regards, baran Last edited by wyldckat; September 28, 2014 at 11:41. Reason: Changed [QUOTE][/QUOTE] to [CODE][/CODE] |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 04:13 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 15:35 |
Flow around pipes - heat transfer coefficient on the wall of pipe | doodek | Main CFD Forum | 2 | November 23, 2009 08:48 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 03:30 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
