How can I use wallHeatFlux with modified icoFoam that has energy equation
I added energy equation to icoFoam. now I want to use wallheatFlux utility for icoFoam.how can I do this?
im very appreciate for any help |
You should add to your transportProperties file:
im appreciate for your reply
gradT
now how I can calculate gradT
foamCalc grad T http://openfoamwiki.net/index.php/Contrib_foamCalcEx Next time try searching in google please. |
I downloaded foamCalcex and compile it according to command in http://openfoamwiki.net/index.php/Contrib_foamCalcEx
but when I write Code:
foamCalc grad T Code:
sajad@sajad-pc:~/Desktop/heatedCavity2$ foamCalc grad T tnx for your replies |
If you downloaded and installed foamCalcEx shouldn´t you use:
foamCalcEx grad T |
tnx for your reply
I calculated gradT and wallHeatflux in wall in my case.now I want to calculate Nusselt Number.I know: Nu=(q*L)/(gradT*k) I just should do a fraction.how can I do it for all feild in order to calculate Nusselt number? I'm appreciate for any help. |
You can do that with the paraView calculator.
i'm appreciate for your helps.
you are right but I want calculate Nusselt Number just around the block.but in paraview calculater it calculate all field Nusselt number while the Nusselt is meaning just around the block.I mean I just want the Nusselt Number of cells around the block. |
Just use Plot Over Line and extract the data over a patch.
You can also load only the desired patch in paraFoam and calculate the Nusselt number inside the patch |
