Display temperature dependent material properties
I am using chtMultiRegionSimpleFoam to simulate a fluid flow passing by heated walls. The material properties (density, viscosity, Cp etc)are temperature dependent.
rhoCoeffs<8> ( x x x ......); |
writeAdditionalFields
In swak4foam there is a utility named writeAdditionalFields. It writes fields other than the default ones but not the material properties.
