My noiseDict
Like Tree3Likes
  • 1 Post By a_habib
  • 1 Post By alexeym
  • 1 Post By chaitanyaarige
Old   February 20, 2015, 15:52
Exclamation My noiseDict
a_habib's Avatar
Ahmad Habib
a_habib is on a distinguished road
Hello every one.
I've spent alot of time searching and looking for the noiseDict because when I tried to use the noise utility the program asked for this dictionary.
Based on the noise.c I built this noiseDict and I don't know if it the correct one
|  \\    /   O peration     | Version:  2.3.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      noiseDict;
    pRef        101325;
    N           65536;
    nw          100;
    fl          25;
    fU          10000;
    graphFormat raw;
    csvFileData
        fileName        "pressureData"
        nHeaderLine     1;
        refColumn       0;
        componentColumns (1);
        separator       " ";
But when I tried to execute the noise command in my terminal in a case folder of a simulation of flow around an obstacle (S-A DDES with a pressure data recorded py a probe) the following error message came out.
a-habib@a-habib:~/test/testCase$ noise
Build  : 2.3.0-f5222ca19ce6
Exec   : noise
Date   : Feb 20 2015
Time   : 19:31:19
Host   : "a-habib"
PID    : 3468
Case   : /home/a-habib/test/testCase
nProcs : 1
Create time
Reading data file
--> FOAM FATAL IO ERROR:
keyword nHeaderLine is undefined in dictionary "/home/a-habib/test/testCase/system/noiseDict.csvFileData"
file: /home/a-habib/test/testCase/system/noiseDict.csvFileData from line 27 to line 31.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 437.
FOAM exiting
So any idea about that definition above ????
chaitanyaarige likes this.
a_habib is offline   Reply With Quote
Old   February 21, 2015, 03:41
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
The reason for the error is missing semicolon after "pressureData".
a_habib likes this.
alexeym is offline   Reply With Quote
Old   May 19, 2015, 05:39
Josef Dobeš
Iose is on a distinguished road
Hello, I try to CAA simulation flow around the cylinder. I finish my simulation and use the probe for measure velocity and pressure behind the cylinder. Now I try by my noiseDict compute SPL. How format do you set up in probeDict?
Iose is offline   Reply With Quote
Old   September 24, 2015, 03:56
Chaitanya
chaitanyaarige is on a distinguished road
noise documentation is incorrect.
Please check the following link for more details:
http://www.openfoam.org/mantisbt/view.php?id=1832
a_habib likes this.
chaitanyaarige is offline   Reply With Quote
caa, noise, noise analysis
